printing multi colors manually
Page 2 / 2
Phil
 Phil
(@phil-16)
RE: printing multi colors manually
Thanks hyiger. What can I do to get the lettering a little crisper? I am using Polymaker PLA for both blue and white. With a .4mm CHT Nozzle that comes with the Core One.
Prusa Core One
Posted : 08/02/2026 9:07 pm
Phil
 Phil
(@phil-16)
I printed it with .20mm layer height instead of .15mm layer height per the instructions. Would that make a difference in the lettering?
https://www.printables.com/model/32160-screw-measuring-tool-m2-m10-4-120mm
Prusa Core One
Posted : 08/02/2026 9:15 pm
No reason to print the entire thing at that resolution just for the text. One way to do this is to instead modify the top layers with a variable layer height. Doing it this way will save ~2hrs of print time.
Depending on the text it might make it clearer. I've done this and attached. To see the preview, after slicing select "Height" in the Legend
Posted : 08/02/2026 10:25 pm
Page 2 / 2
