Print Issus Blobs
docsascha
(@docsascha)
Print Issus Blobs
Using PRUSAment PLA Blend Viva LaBronze and having prints resulting in Issus like the ones in the picture.
CoreOne Plus, HF Obxidian 0,4 Nozzle
Pla was dryed for 6 hours
Printed PRUSAment PA-CF before
Clogged Nozzle?
PLA not dry enough?
Others reasons?
Best Answer by hyiger:
This looks like you have the "Seam position" set to Random. Check in Print Settings -> Layers and perimeters -> Seam Position
Postato : 03/01/2026 3:13 pm
docsascha
(@docsascha)
RE: Print Issus Blobs
Did the same print with another PLA,
Same results with -interestingly- nearly the same blob pattern
I would thing it's an partly clogged Nozzle.
Would a cold pull with an HF Nozzle work ?
Sascha
Postato : 03/01/2026 4:11 pm
Postato : 03/01/2026 4:30 pm
1 persone hanno apprezzato
docsascha
(@docsascha)
Thank you , changed the setting and Bloobs are gone
Best wishes
Sascha
Postato : 03/01/2026 5:20 pm
