					                		Pin Holes - How do I print this? (Printing help)                                    </title>
                <link>https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/pin-holes/</link>
                <lastBuildDate>Sun, 07 Jun 2026 11:57:29 +0000</lastBuildDate>
                        <title>RE: Pin Holes</title>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/pin-holes/#post-765056</link>
                        <pubDate>Sat, 20 Sep 2025 03:58:37 +0000</pubDate>
                        <description><![CDATA[Thank you for your reply Tim. The test part is 3 layers thick. When I got home I adjusted the extrusion multiplier from 1 to .9 (picture 1). The problem was a little worse so I went to 1.1 (...]]></description>
                        <content:encoded><![CDATA[<p>Thank you for your reply Tim. The test part is 3 layers thick. When I got home I adjusted the extrusion multiplier from 1 to .9 (picture 1). The problem was a little worse so I went to 1.1 (picture 2) and it really improved the pin holes. I might have some slight adjusting left to do (had a little more stringing than usual), but your advice really helped. Thank you again for your prompt reply!</p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/09/4e1330ad-1-scaled.jpg"><img class="alignnone size-medium wp-image-180437" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/09/4e1330ad-1-600x500.jpg" alt="" width="600" height="500" /></a><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/09/57d1d9a4-2-scaled.jpg"><img class="alignnone size-medium wp-image-180438" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/09/57d1d9a4-2-600x500.jpg" alt="" width="600" height="500" /></a></p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>Bryan Powell</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/pin-holes/#post-765056</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/pin-holes/#post-765015</link>
                        <pubDate>Fri, 19 Sep 2025 19:42:00 +0000</pubDate>
                        <description><![CDATA[You didn&#039;t say how many layers are involved. But initial thoughts are a slight under extrusion - filament multiplier could be set a tad higher. You might try reducing elephant foot comp, not...]]></description>
                        <content:encoded><![CDATA[<p>You didn't say how many layers are involved. But initial thoughts are a slight under extrusion - filament multiplier could be set a tad higher. You might try reducing elephant foot comp, not sure how that will affect gap fill, but is one of the levers available. The others are retraction settings... </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>Tim</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/pin-holes/#post-765015</guid>
                        <title>Pin Holes</title>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/pin-holes/#post-764937</link>
                        <pubDate>Fri, 19 Sep 2025 08:09:07 +0000</pubDate>
                        <description><![CDATA[Hello,I am attempting to print a lightbox for a birthday gift. Before printing the entire thing, I wanted to print a test part to ensure everything printed properly. Upon inspecting the test...]]></description>
                        <content:encoded><![CDATA[<p>Hello,</p><p>I am attempting to print a lightbox for a birthday gift. Before printing the entire thing, I wanted to print a test part to ensure everything printed properly. Upon inspecting the test part I noticed these pin holes in the attached (picture 1). I also noticed that there is another section that does not look like it extruded properly (picture 3). While I am not new to 3D printing, I am new to PrusaSlicer and the CORE One. I am using VOXEL PLA, standard .04 nozzle, and the factory .20mm structural print setting. My filament has been dried, and is stored in a cereal dry box with desiccant. The hygrometers both read 20% humidity. The lightbox was designed in Fusion and put a .2 mm fillet on all applicable corners. I printed two test parts (one with door closed, one with door open) with identical results. Does anyone have any advice on how to remedy these issues? Thank you in advance!</p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/09/87f2f757-1-scaled.jpg"><img class="alignnone size-full wp-image-180411" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/09/87f2f757-1-scaled.jpg" alt="" width="1920" height="2560" /></a> <a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/09/264f16aa-2-scaled.jpg"><img class="alignnone size-medium wp-image-180412" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/09/264f16aa-2-600x500.jpg" alt="" width="600" height="500" /></a> <a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/09/cb83847f-3-scaled.jpg"><img class="alignnone size-medium wp-image-180413" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/09/cb83847f-3-600x500.jpg" alt="" width="600" height="500" /></a></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/pin-holes/#post-764937</guid>
