					                		PETG and ObXidian 0.6 HF nozzle - How do I print this? (Printing help)                                    </title>
                <link>https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/petg-and-obxidian-0-6-hf-nozzle/</link>
                <lastBuildDate>Thu, 11 Jun 2026 07:48:39 +0000</lastBuildDate>
                        <title>RE: PETG and ObXidian 0.6 HF nozzle</title>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/petg-and-obxidian-0-6-hf-nozzle/#post-747618</link>
                        <pubDate>Mon, 28 Apr 2025 13:41:43 +0000</pubDate>
                        <description><![CDATA[Prusament PLA has 24 mm3/s (generic PLA 22 mm3/s) in slicer profile, but Core One PLA sample prints goes up to 34 mm3/s (with regular PLA). The Nextruder with high flow nozzles is very power...]]></description>
                        <content:encoded><![CDATA[<p>Prusament PLA has 24 mm3/s (generic PLA 22 mm3/s) in slicer profile, but Core One PLA sample prints goes up to 34 mm3/s (with regular PLA). The Nextruder with high flow nozzles is very powerful. <a href="https://e3d-online.com/pages/prusa-mk4-support-high-flow-obxidian" target="_blank" rel="noopener">E3D documentation</a> states that 0.6mm HF ObXidian should run PETG at 240°C at rate 36 mm3/s. With bumping a temperature a bit it should go even more. Also high flow filaments may give it a significant boost. I have not tried to find a limit yet, but I would expect it to be more than 40 mm3/s (depending on filament used).</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>Biomech</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/petg-and-obxidian-0-6-hf-nozzle/#post-747618</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/petg-and-obxidian-0-6-hf-nozzle/#post-747484</link>
                        <pubDate>Sun, 27 Apr 2025 11:13:02 +0000</pubDate>
                        <description><![CDATA[31mm3/s is quite high, for the hotend of this printer. PLA will be maybe OK. but PETG is often a nasty customer, specially when it&#039;s a bit wet. As a safe rule, I wouldn&#039; t go higher than 25m...]]></description>
                        <content:encoded><![CDATA[<p>31mm3/s is quite high, for the hotend of this printer. PLA will be maybe OK. but PETG is often a nasty customer, specially when it's a bit wet. As a safe rule, I wouldn' t go higher than 25mm3/s or so (.. good luck fixing a clog in a HF nozzle ). Anyway, the possible trouble with the volumetric speed being too high. would be rather underextrusion than clogging. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>Artur5</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/petg-and-obxidian-0-6-hf-nozzle/#post-747484</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/petg-and-obxidian-0-6-hf-nozzle/#post-747449</link>
                        <pubDate>Sat, 26 Apr 2025 20:04:41 +0000</pubDate>
                        <description><![CDATA[If you want to know the limit, you have to run volumetric speed test for your filament. Values in slicer filament profiles are more likely safe than maximum.]]></description>
                        <content:encoded><![CDATA[<p>If you want to know the limit, you have to run volumetric speed test for your filament. Values in slicer filament profiles are more likely safe than maximum.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/petg-and-obxidian-0-6-hf-nozzle/#post-747449</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/petg-and-obxidian-0-6-hf-nozzle/#post-747383</link>
                        <pubDate>Sat, 26 Apr 2025 12:42:38 +0000</pubDate>
                        <description><![CDATA[Well, it’s 31 mm3/s.  That’s why it’s called MAX Volumetric Speed.]]></description>
                        <content:encoded><![CDATA[<p>Well, it’s 31 mm3/s.  That’s why it’s called MAX Volumetric Speed.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>LarGriff</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/petg-and-obxidian-0-6-hf-nozzle/#post-747383</guid>
                        <title>PETG and ObXidian 0.6 HF nozzle</title>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/petg-and-obxidian-0-6-hf-nozzle/#post-747365</link>
                        <pubDate>Sat, 26 Apr 2025 10:14:32 +0000</pubDate>
                        <description><![CDATA[The default volumetric speed in Prusa Slicer for PETG and 0.6 HF nozzle is 31 mm3/s (both for Prusament and generic PETG). What is maximum value non resulting in risk of clogging? What is yo...]]></description>
                        <content:encoded><![CDATA[<p>The default volumetric speed in Prusa Slicer for PETG and 0.6 HF nozzle is 31 mm3/s (both for Prusament and generic PETG). What is maximum value non resulting in risk of clogging? What is your experience?</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>reinvented.tech</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/petg-and-obxidian-0-6-hf-nozzle/#post-747365</guid>
