PET-CF config
Phil
 Phil
(@phil-15)
PET-CF config
I bought a spool of Siraya Tech PET-CF. On my Core One there isn’t a PET choice when loading filament. What do I do?
Prusa Core One
Postato : 14/06/2026 6:01 pm
You create one. I'm not in front of my printer right now but you can go to the filament user presets screen on the printer and simply add it. I can give you exact instructions later.
What nozzle do you plan to use with it? My advice is to use a hardened 0.6mm and not high flow.
Let me know and I'll attach a calibrated profile for it. Just be aware that PET-CF is at the upper limit of what can be successfully printed on the Core One. Meaning you'll need to run the nozzle at 290° but PET-CF likes 300 or 310
Questo post è stato modificato 13 hours fa 3 tempo da hyiger
Postato : 14/06/2026 6:48 pm
Phil
 Phil
(@phil-15)
RE: PET-CF config
I have a 0.6mm hardened nozzle (not HF) that I can use.
Prusa Core One
Postato : 14/06/2026 7:57 pm
@phil-15
Filament -> Manage Filaments -> Edit Filaments -> (scroll until you see @User1) ->
  • Name: PET-CF
  • Visible: On
  • Nozzle Temperature: 290
  • Nozzle Preheat Temperature: 170
  • Bed Temperature: 70
  • Nominal Chamber Temperature: None
  • Minimum Chamber Temperature: None
  • Maximum Chamber Temperature: 55
  • Is Abasive: On
  • Auto Retract: On
  • Requires Filtration: Off
Questo post è stato modificato 12 hours fa 3 tempo da hyiger
Postato : 14/06/2026 8:01 pm
Posted by: @phil-15
I'll send you a profile shortly. I haven't actually printed this filament on a Core One, I use my H2D for that. I have printed Fiberon PET-GF on a Core One which has a lower temperature requirement.
Just be aware that on a Core One with a 290° limit, you are at the lower end of the temperature range so there might be layer adhesion issues. Also, this filament is very brittle.
Questo post è stato modificato 12 hours fa da hyiger
Postato : 14/06/2026 8:23 pm
RE: PET-CF config
@phil-15
Try this one. You might need to lower the max volumetric flow slightly since this is calibrated for a 0.6mm Diamondback nozzle.
Postato : 14/06/2026 11:07 pm
