[Gelöst] persistent adhesion issue on my Prusa Core One
Artnow
(@artnow)
Hello everyone,
I’m experiencing a persistent adhesion issue on my Prusa Core One when printing ABS:
Setup and settings– Printer: Prusa Core One in a closed enclosure– Material: ABS– Bed temperature: 115 °C– Nozzle temperature: 250 °C– First layer calibrated with 7×7 mesh bed leveling– 6 mm skirt around the part
Problem– At about 5 mm height, the part lifts only on the right side, starting at the corners– The left side remains perfectly adhered– The part is rectangular and almost covers the entire build plate– I’ve flipped the textured sheet (cleaned with isopropyl alcohol) multiple times, but the issue persists
Troubleshooting already done
Cleaned the textured sheet with isopropyl alcohol
Printed inside a closed enclosure (no noticeable drafts)
Used 7×7 mesh bed leveling
Reoriented the sheet by flipping it
Thank you for any suggestions!
Have you seen a one-sided adhesion issue on Core One before?
How can I diagnose potential thermal or flatness variations on the right side?
Which settings or accessories (adhesive, brim, “mouse ears”) do you recommend for a large ABS part?
Veröffentlicht : 19/10/2025 5:59 pm
Artnow
(@artnow)
RE: persistent adhesion issue on my Prusa Core One
solved
Veröffentlicht : 20/10/2025 6:45 pm
Posted by: @artnow
solved
For the sake of others who may have a similar issue in the future, could you elaborate on how you solved it?
Veröffentlicht : 20/10/2025 6:46 pm
mnentwig
(@mnentwig)
I can only speak about my own ABS observations. To me, the main challenge is that the material contracts, about 0.4 % per the "calibrated" XY correction factor that gives correct final dimensions.
In my printer, the front right edge - that is where the door closes - is the most sensitive: For large, flat prints, this corner detaches first.
An example, below (I'm throwing LEGO problems at the poor printer just for laughs and the learning experience. This one was, if I remember correctly, without brims and support, which will also trigger warnings from Prusa Slicer. Printing time probably around 8h).
Veröffentlicht : 20/10/2025 9:28 pm
Artnow
(@artnow)
Hello, here are the settings I made to get my print working
I’m also attaching the configuration file. Have a great day!
General Information
Profile and Printer– print_settings_id: 0.20mm BALANCED @COREONE HF0.4 – last IA– printer_model: COREONE with 0.4 mm high-flow nozzle– filament_type: Generic ABS @COREONE HF0.4
Layer and Height Settings
layer_height: 0.20 mm (balanced quality and speed)
first_layer_height: 0.20 mm
min_layer_height: 0.07 mm / max_layer_height: 0.30 mm
bottom_solid_layers: 3 layers
top_solid_layers: 5 layers
bottom_solid_min_thickness: 0.50 mm
top_solid_min_thickness: 0.70 mm
Temperatures
first_layer_temperature: 258 °C
temperature (subsequent layers): 255 °C
idle_temperature: 140 °C
first_layer_bed_temperature: 120 °C
bed_temperature (subsequent): 115 °C
chamber_minimal_temperature: 20 °C
Print Speeds
first_layer_speed: 45 mm/s
perimeter_speed: 150 mm/s
external_perimeter_speed: 200 mm/s
small_perimeter_speed: 170 mm/s
infill_speed: 150 mm/s
solid_infill_speed: 150 mm/s
top_solid_infill_speed: 100 mm/s
travel_speed: 350 mm/s
bridge_speed: 50 mm/s
Accelerations
default_acceleration: 3000 mm/s²
first_layer_acceleration: 500 mm/s²
perimeter_acceleration: 3000 mm/s²
external_perimeter_acceleration: 2500 mm/s²
infill_acceleration: 5000 mm/s²
solid_infill_acceleration: 5000 mm/s²
top_solid_infill_acceleration: 2000 mm/s²
bridge_acceleration: 1500 mm/s²
travel_acceleration: 7000 mm/s²
Dynamic acceleration reduction by height (via before_layer_gcode):– 0–150 mm: 7000 mm/s²– 200 mm: 4000 mm/s²– 270 mm: 2000 mm/s²
Extrusion Widths
extrusion_width: 0.45 mm
first_layer_extrusion_width: 0.50 mm
perimeter_extrusion_width: 0.45 mm
external_perimeter_extrusion_width: 0.45 mm
infill_extrusion_width: 0.45 mm
solid_infill_extrusion_width: 0.45 mm
top_infill_extrusion_width: 0.42 mm
Infill
fill_density: 15%
fill_pattern: grid
fill_angle: 45°
infill_overlap: 15%
bottom_fill_pattern: monotonic
top_fill_pattern: monotoniclines
Perimeters and Shell
perimeters: 2
perimeter_generator: arachne
ensure_vertical_shell_thickness: on
external_perimeters_first: off
Retraction
retract_length: 0.70 mm
retract_speed: 45 mm/s
deretract_speed: 25 mm/s
retract_before_travel: 1.50 mm
retract_lift (Z-hop): 0.20 mm up to Z=269 mm
retract_before_wipe: 80%
Cooling
min_fan_speed: 0%
max_fan_speed: 0%
bridge_fan_speed: 0%
disable_fan_first_layers: 5
(No part cooling fan for ABS to avoid warping.)
Supports
support_material: on
support_material_auto: on
support_material_threshold: 35°
support_material_pattern: rectilinear
support_material_spacing: 2 mm
support_material_contact_distance: 0.20 mm
support_material_interface_layers: 3
support_material_style: snug
Brim
brim_width: 8 mm
brim_type: outer_only
skirts: 0
Dimensional Compensation
elephant_foot_compensation: 0.20 mm
xy_size_compensation: 0 mm
z_offset: 0 mm
Pressure Advance / Linear Advance
In start G-code, pressure advance is set per nozzle size:
0.4 mm nozzle: M572 S0.02
0.5 mm nozzle: S0.018
0.6 mm nozzle: S0.015
0.8 mm nozzle: S0.01
Custom G-Code
Start filament G-code– 7 mm purge, wipe on bed edge, 0.5 mm retraction to avoid blobs.
End filament G-code– Turn off temperatures, lower bed to Z=180 mm, park head at X220 Y200, disable motors.
Veröffentlicht : 21/10/2025 8:31 am
Artnow
(@artnow)
my GCODE :
; === Dynamic pressure and heatbreak settings by nozzle ===M572 S{if nozzle_diameter[filament_extruder_id]==0.4}0.02{elsif nozzle_diameter[filament_extruder_id]==0.5}0.018{elsif nozzle_diameter[filament_extruder_id]==0.6}0.015{elsif nozzle_diameter[filament_extruder_id]==0.8}0.01{elsif nozzle_diameter[filament_extruder_id]==0.25}0.09{elsif nozzle_diameter[filament_extruder_id]==0.3}0.065{else}0{endif} ; Filament g-codeM142 S40 ; set heatbreak target temperature
; === Anti-residue filament start sequence ===G92 E0 ; Reset extruder positionG1 Z0.3 F1000 ; Slightly raise the nozzleG1 X5 Y5 F3000 ; Move the head to a cornerG1 E7 F400 ; Purge 7 mm of filament to primeG1 X60 F1200 ; Wipe the filament tip on the bed edgeG1 E-0.5 F1800 ; Light retraction to avoid a filament blobG92 E0 ; Reset extruder again
; === Print start ===
Veröffentlicht : 21/10/2025 8:35 am
For what it's worth, Prusa's material guide states that glue stick must be used when printing ABS on the textured build plate:
https://help.prusa3d.com/filament-material-guide
Veröffentlicht : 21/10/2025 9:21 am
Artnow
(@artnow)
Hello, I now have good printing results, no need for glue stick, I would never use such a process, with the right settings, the results are excellent, I also avoided several failures by monitoring the start of the leveling tests and the start of printing by removing a small filament droppings under the printing nozzle which was distorting the good gluing of the border around the part. To put it simply: When the nozzle is clean from the beginning to the end of the steps, the parameters are well adjusted and the first layer is well adjusted with the right températures corresponding to the type and recommendations of the manufacturer, then the printing is great!
Veröffentlicht : 24/10/2025 5:36 am
mnentwig
(@mnentwig)
What's wrong with glue stick? It's a very robust process, layer thickness matters little as the print "floats" on the PVA, regardless how thick it is.
Meaning, "robust" compared to cleaning, where "residual dirt" is hard to control: Overdo the cleaning, and prints get very hard to remove (especially thin layers - very annoying when having to abort a print, thinking about wipe towers rendered for super. strong. adhesion...).
Veröffentlicht : 24/10/2025 5:11 pm
Artnow
(@artnow)
Hello mnentwig,
Thank you for this pertinent observation! You're right about the robustness of the PVA process, but you're pointing out exactly the problem I've solved: it's not just about cleaning, it's a globally parameterized approach.
My results come from a precise combination of critical settings:
1. Cooling Fan — THE fundamental parameter
First layer : cooling fan 0% or very low (5-10% max) — otherwise too rapid cooling = delamination and poor adhesion
Following layers : progressive increase to 80-100% depending on the filament
This was my first bottleneck. Poorly tuned cooling ruins both adhesion AND quality
2. First layer height — The critical adjustment
Nozzle offset: ±0.05mm max precision
Too high = filament won't stick / Too low = crushing and impossible to remove
Manual verification: the filament should leave a very slight black trace under the nozzle
3. Adapted thermal profiles — THE often-forgotten key
First layer : 263°C nozzle / 115°C bed (ABS with your configuration)
Layers 2-3 : progressive decrease to 260°C nozzle / 110°C bed
Following layers : stabilization at 255-258°C nozzle / 105°C bed
First layer 20-30°C hotter than the rest = adhesion without overheating afterwards
Regarding the glue stick:
You may very well be right about its effectiveness, but honestly I found this solution limited. Sure, Prusa documents it officially, but the bed ends up clogged with dried glue, which ironically deteriorates adhesion for subsequent prints.
On my end, I simply wipe the bed with isopropyl alcohol every 2-3 prints to keep the PVA clean — it's infinitely simpler and more effective than regular glue maintenance.
With the right parameterized configuration, this simple cleaning is enough. Prints stick properly and remove easily without this vicious cycle of glue accumulation.
Proof in action: since this optimization, I've completed around fifteen beautiful ABS and PLA prints without any adhesion issues. It's really stable and reliable now.
I believe your negative experience with cleaning was probably masked by a poorly calibrated first layer or suboptimal cooling settings. With the right overall configuration, it's a reliable and clean process.
Best regards,ARTNOW
Veröffentlicht : 26/10/2025 6:45 pm
mnentwig
(@mnentwig)
Thanks for the feedback. I'm sure glue stick is not necessary - many people never touch it.
Still, I'd argue it's attractive for its robustness, you get a fresh layer every time.
BTW, "PVA" = polyvinyl alcohole. That's the standard-issue glue stick (there is one alternative substance, depending on brand that is not "exactly" PVA but reportedly acts just the same).
Veröffentlicht : 26/10/2025 7:46 pm
