PC CF horizontal layer ripples
ajemutt
(@ajemutt)
Hi there.
I'm trying to print an outlet cover using PC-CF on a Core1.
Slicer 2.9.2
FW 6.3.4+10511
Obxidian .4 nozzle
IEMAI PC-CF filament
Stock Prusa smooth sheet
Purple glue stick
My slicer settings are the stock Prusament PC-CF Blend profile.
Nozzle @ 285c
Bed@ 100c
I've tried it both with the chamber temp set to 40c and 55c.
This photo is from the solid 3rd layer. The resulting part is perfectly functional, but I'm curious as to what's causing the terrible ripples. Is it because I'm printing too hot or too cold with the nozzle or bed? Or is my extrusion multiplier too high?
Thx!
Posted : 10/10/2025 10:58 pm
The filament is over extruded. Prusa sets an extrusion multiplier 1.04 for their PC-CF. For IEMAI PC-CF it should be more like 0.85 or 0.90 for this filament. IEMAI recommends 230-250°C hot-end, bed temperature of 60-80°C, and print speed of 30-100mm/s. 285C is too high.
Also it may be damp. PC filaments are hydroscopic and need to be dried before you use them. You should dry it at 70C for 8hrs before printing with it.
Anyway, I owned a spool of this filament. IEMAI PC-CF in particular is very brittle and interlayer adhesion is poor. I ended up throwing my spool away. Also CF based filaments are not a good choice and is probably the worst filament to use for an outlet cover given its not as impact resistant as other filament types. PC (not PC-CF), (example PC Blend), PA (again not PA-CF) or ASA is a much better choice.
This post was modified 20 hours ago by hyiger
Posted : 10/10/2025 11:16 pm
My edit window closed but I wanted to add that you can't use Prusa's settings for another vendor's filament. It generally won't work unless it's a basic filament like PLA or PETG. Always read the data sheet for that filament and use the manufacturer's recommended settings.
Posted : 10/10/2025 11:22 pm
ajemutt
(@ajemutt)
RE: PC CF horizontal layer ripples
Thanks. That all makes sense. I did dry it for 8 hours@80c, so I'll jump right into getting IEMAI's settings figured out.
Much appreciated!
Posted : 10/10/2025 11:29 pm
Try the following:
  • Nozzle: 240C
  • Bed: 80C
  • Extruder Multiplier: 0.90
Also with this type of filament you will sometimes need to anneal it afterwards, example at 110C for around 4hrs. That said, the roll I had was crap. There is a discussion about it here:  https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/printing-with-pc-cf-keeps-lifting-off-print-bed/
Prusa PC-CF is an excellent filament and I have 2 rolls of it. However, it's almost never in stock.
Again though, for an electrical outlet cover I recommend (the non CF versions of): ASA, PC,  or PA12. Of the 3, ASA is by far the easiest to print.
This post was modified 20 hours ago 3 times by hyiger
Posted : 11/10/2025 12:01 am
gb160
(@gb160)
For IEMAI PC-CF I'm using extrusion multiplier of 0.9
I'm hesitant to buy another roll of this due to the QA, the roll I have (and have nearly finished) was fine, but loads of people seem to have had bad rolls, I must've got lucky but I'm not sure I want to roll the dice with IEMAI again.
Really wish there were some more competitively priced PC-CF options out there, there's no way I'm paying Prusa prices for PC CF.
Posted : 11/10/2025 2:45 pm
Posted by: @gb160
There is this: YXPOLYER PC-CF reviews look OK. However not will to take another chance. I've been printing a lot of PC-CF recently for my model rocket hobby and even though the Prusa filament is expensive, it works. I've gone through 2 spools without any issues. My one gripe is that the spools have to be screwed together before throwing it in the dryer or the adhesive comes loose...
Posted : 11/10/2025 3:41 pm
Posted by: @hyiger
OMG, I hate this short edit window on posts. Shouldn't type anything before my second cup of coffee... I sound like Yoda. Anyway, I wanted to add that CF filaments in general have been hit or miss for me. I've been doing some printing in some formulations of PC since it's cheaper but it's really hard to print. Have to pay a lot of  attention to warping. PA-CF (I have Fiberon PA6-CF20) is OK but as with most nylon filaments it needs to be dried before each use.
Posted : 11/10/2025 3:56 pm
gb160
(@gb160)
Posted by: @hyiger
Posted by: @gb160
Yeah that one looks ok and has had some quite good reviews on here, but not available on Amazon UK without paying around £9 shipping, so it works out around £40 all in.
If I knew 100% it was good filament I'd give it a try, but thats quite a few quid to spend on a gamble.
Posted : 11/10/2025 4:26 pm
