Overcooked Filament?
David R. Campbell
(@david-r-campbell)
I discovered this morning that dryer that I put an almost full spool or Prusament PETG last night was set for 65 degrees C (for a previous spool of TPU).
Did I just waste an almost full spool?
Opublikowany : 08/03/2026 5:40 pm
RE: Overcooked Filament?
Posted by: @david-r-campbell
Unless you see obvious signs of melting you are probably OK. I've dried PETG at that temp without causing it any harm.
Opublikowany : 08/03/2026 5:51 pm
As long as you stay below the glass transition temperature for a filament you should be OK.  For PETG this is roughly 80°C but it varies slightly depending on manufacturer, glycol percentage and pigment type - so as long as your dryer is reporting temperature correctly and remaining stable (some hunt up and down around the target value) - you are safe.
Opublikowany : 09/03/2026 1:48 am
