How may I add support to avoid this artifact?
internetsale cosner
(@internetsale-cosner)
Miembro
I have tried several approaches to removing a flaw in a print and I have failed. I ask for your assistance in allowing me to fix this flaw.
I have attached STL, 3MF, and G-code files (ZIP’d) so that you can see what I did. These files represent, just a portiont of a larger part from which the example files were removed for this print. I printed this part, and it does exhibit the flaw.
I printed this on a factory-assembled CORE One with current firmware and with the current Prusa Slicer in Overture PETG. While printing, I can see that the problem is Y-axis vibration as the print head gets further from the base. The problem stops when printing bridges the top of the “window” thereby connecting and stabilizing the panel.
I believe that what I need to do is to provide a support resisting Y-axis motion on the unsupported panel in the problem area. It seems like that type of support is not available in the slicer. Additionally, this part, in production will have a fuzzy skin, and it seems that the current slicer does not allow for both supports and fuzzy skin.
To work around my lack of knowledge regarding support options, I jury-rigged a “plug” in the “window” with spaced projection-points on sides, top, and bottom of the “window” to stabilize the otherwise unsupported panel. With trial and error, I found that a 0.003-inch clearance provided a plug that did stabilize and was removable, yet it left unacceptable residuals on the window edges.
I have likely overlooked some built-in solution or easy workaround. Will you please help me out and educate me?
Respondido : 28/09/2025 11:17 pm
RE: How may I add support to avoid this artifact?
have you tried turning the part 90 degrees?
another option is to add a diagonal brace at 45 degrees to the long gap, ending just below where the unsupported wall starts thinning, to stiffen it up a little the 45 degree angle should negate the need for full height support.
Respondido : 29/09/2025 1:08 am
