Dialing in Prusament PC Blend on a Core One
I have a big project coming up and bought several rolls of Prusament PC Blend. First thing I did was print out a Benchy with the Prusament PC Blend profile 0.4mm Diamondback, 0.20 STRUCTURAL. Prusa set the max flow rate to 12 mm^3/s which is probably a tad conservative. Before I waste a bunch of (expensive) filament trying to dial-in a faster setting has anyone does this yet? Otherwise I guess I can fire up OrcaSlicer and run the volumetric flow test.
Anyway, this filament is really nice. Best Benchy out of all my filaments.
RE: Dialing in Prusament PC Blend on a Core One
At least in my case, the 0.18% X,Y,Z shrinkage compensation was slightly too small. I calibrated it to 0.75%
So what type of part are you making?
Actually now it's two projects. The first is a fin assembly (and possibly nose cone) for a model rocket, the second is long spars for the INBXX - for PRUSA INDX in preparation for when I receive my INDX kit. In both cases I need dimensionally accurate parts and PC can be tricky if it's not correctly dialed-in.
What is interesting for the rocket parts is I was originally using PC-CF and PA-CF under the (now naive) impression that they would be stronger than the "blended" PC and PA filaments. They are certainly much easier to print than PC or PA and don't warp (as much). But the chopped carbon fibers actually make the parts weaker and less impact resistant.
I just had a nephew build and fly a Gen 2 rocket. Not sure how he made the rocket. Don't think he printed it.
For the RC model planes, they recommend the LW-PLA. The first plane I made was just in the PLA. I didn't finish my plane in the LW-PLA.
The big issue is that they have trouble with warping in the sun. So I probably should switch to a higher temperature filament.
For something like a plane or drone I would think some sort of ASA filament would also be a good choice. Especially given that it's UV resistant. PC filaments would also be an excellent choice if you can control the warping. PC-CF is an exception but it's even more expensive than PC Blend. Probably a good compromise would be a combination of LW-PLA and PC-CF.
Like the Estes kits that were around when I was a kid (and are still around) the beginners tubes are usually phenolic cardboard. For the Level 1 and 2 rockets (the big boy versions) there are kits available and the tubes are typically fiberglass, carbon fiber epoxy or phenolic resin. If printing your own then generally PA-CF or PP seems to be the better choice. When you get to Level 3 then 3D printed rockets have a tendency to fall apart (literally). I'm not there yet but plan on getting there eventually.
Another fun fact that I forgot about... Black PC Blend warps more than Orange PC Blend given that black will have different thermal properties than orange. Printing the same part with black PC requires a brim whereas I don't need one with orange.
Another fun fact to add to this thread. I'm able to get very strong bed adhesion using a Garolite G10 plate. The build plate itself is a non-spring steel plate and is not easily bendable by hand. However when the parts cool down and shrink they actually pull the sides of the plate off of the print bed.
Best to try the "Balanced" profiles first as they're supposedly dialed in for the Core One.
It really depends on what (the geometry) you are printing. The balanced profiles are OK but really not the best choice for large PC parts since it can increase the chance of warping.
What is the effect of annealing the parts?
In the case of PC blends (not just Prusa) it not only doesn't really create a benefit but it can also damage the part. In particular for functional parts (which this is), you'll loose precision. All for maybe a 5-10° gain in heat deflection (maybe).
Sorry to go OT from your original post @hyiger but your statement that CF blend filaments are weaker then straight filaments intrigued me. I was going to try some PETG-CF along with PCTG for a little more strength than my traditional PETG without having to vent my case. But your comment is making me second guess the PETG-CF. Seems like what I see on searches says PETG-CF is stronger than plain PETG. Do you have any experience with it?
Don't believe the marketing hype. CF doesn't make prints stronger, it makes them easier to print with less warping and improves heat resistance. Adding CF to PETG gives it a nice matte finish but that's about all. What it takes away is inter-layer adhesion. The reason is that the carbon fibers get between the layers but not through the layers and weakens the part in the Z direction. If you need better stiffness and impact resistance then PC, ASA and PA or better choices.
Start a new thread on this and I'll be happy to contribute. It's an interesting subject. If you want more rigorous testing results, head over to this channel on YouTube: https://www.youtube.com/@MyTechFun
