CoreONE and TPU - How to
Page 1 / 2
96ToyotaCamry
(@96toyotacamry-2)
Hello everyone,
I searched about the CoreONE and TPU and it is hard to find a how-to for this type of filament.
What would be the necessary steps to print TPU on the CoreONE?
- nozzle type? and size?
-steel plate type?
- what profile to use?
- Any custom modification to the printer?
- Type of TPU filament (example 95A, 85, 60... ?)
Thank you !!!
Posted : 29/04/2025 12:38 pm
I think all of Prusa's general guidance on printing TPU applies:
https://blog.prusa3d.com/how-to-print-with-flexible-filament_29672/
There is also a Core One-specific thread right in this forum section:
https://forum.prusa3d.com/forum/postid/738556/
Posted : 29/04/2025 2:00 pm
Scott
(@scott-18)
RE: CoreONE and TPU - How to
Posted by: @96toyotacamry-2
Hello everyone,
-steel plate type?
Thank you !!!
- The bigger the nozzle is the better, but 0.4 should do for 85A+ TPU (no matter what type of nozzle)
- Textured plate is the best way to go IMO
- You can start with any TPU profile like Ninjaflex one
- No modification needed, but bypassing the PTFE tube (and so the right filament sensor) is the best way to print TPU
- I managed to print any TPU harder than 83A (Ninjaflex). I didn't manage to print softer
Yürgen gave you nice links to help! 🙂
Posted : 29/04/2025 8:49 pm
96ToyotaCamry
(@96toyotacamry-2)
Thank you Scott and Yürgen!
Trying to bypass the PTFE tube on a CoreONE is a pain... I guess the printer is not ready (out of the box) for TPU...
Messing around with the PrusaSlicer, I found the TPU profiles but they all have an * on the side, and looking at the * description is says not compatible with your printer.
Others on forums are saying that you need a different nozzle other than the stock one that ships with CoreONE... Maybe I will try on my MK4S first, (easy to clean any mess) the CoreONE is a box that if you have to service any big issues with the nozzle, you have to figure out a way to pull out the top part.
Posted : 29/04/2025 9:49 pm
George
(@george-4)
Just something to add here, i tried a normal 40D TPU and it prints fine. No issues. But when i tried Varioshore tpu from colorfabb, oh man. after a couple of layers, i got into trouble. This tpu was printing fine with my mini+ for years, but with core one it keeps having issues. It buckles and goes into a gab between the motor and the hear housing.
So i'll be printing a modified part from printables in PC and hope it makes it easier.
Posted : 30/04/2025 6:51 am
Rainer
(@rainer-2)
I haven't printed TPU on my Core One yet, but I have on the MK4S, which has the same print head.
The only thing I have to adjust is the pressure of the exdruder.
I always turn both screws 1.5 turns counterclockwise.
Then I have no problems at all, even with a PTFE tube.
I see no reason why it shouldn't work the same way with the Core One.
Posted : 30/04/2025 10:01 am
George
(@george-4)
"normal" 40D tpu prints fine, i had no issues. But Colorfabb's varioshore is kinda special i guess 😀 I just going boing and pushes itself into the empty space between the motor and the first plastic piece.
Posted by: @rainer-2
Posted : 30/04/2025 10:21 am
Rainer
(@rainer-2)
This is also the problem I have when I don't loosen the idler screws
Posted : 30/04/2025 10:45 am
boB
 boB
(@bob-3)
Finally got TPU (NinjaFlex 85A) to print. It took removing the tube to the extruder; hanging the spool about 1 meter above the printer; trying 3 times to load the filament. Once the filament was loaded it all went well. I use a small strip of thin masking tape where the nozzle cleaning takes place, it keeps the plate cleaner. I did not change the extruder tension. The tension on the filament seemed high but it worked. I will make a better spool holder with less friction for next time.
The print was stuck to the smooth plate really well, swabbing some alcohol and flexing the print repeatedly got it to come loose. Once it was done I loaded PLA and did a few purges to clear out the TPU.
Posted : 30/04/2025 3:12 pm
63alfred
(@63alfred)
Very helpful posts.
I am printing NinjaTek Cheetah TPU.  Yes loading the filament is tedious as you must remove the top of the Core One to get easy access to the top of the extruder, then slide back the black 3D printed guide that allows the filament to make a 90n degree turn then push down on the quick-connect fitting that secures the PTFE tube to the extruder to remove it.  Kinda difficult as you have to press it down symmetrically and this is difficult with such a small diameter fitting and big human fingers.  Alas, after a few tries yes it will come out.  Then you can manually feed the filament until it engages the sensor and the machine does the rest.
Reassemble and start printing.  Used the NinjaTek Cheetah TPU preset that comes with PrusaSlicer so the printer automatically prints about 3 X slower than with PLA.
Did not adjust the tension as mentioned in the video for the XL.  Seems to be printing fine, we will see the results in 3 hours or so!
Posted : 11/05/2025 9:33 pm
ThomasF
(@thomasf)
This is really disappointing IMO. I also had a quite the battle with TPU, Ultrafuse 95A. Just could not get it to load. I ended up giving up on printing TPU on the CoreOne. There's just no way I'm taking stuff apart just to feed it TPU. Thats not why I got the CoreOne.
Instead, good old MK3s has been promoted to chief TPU printer.
Posted : 25/07/2025 8:51 pm
mrbunky13
(@mrbunky13)
I have been attempting to print some parts in Hatchbox 95A TPU.  Here are some things that allowed most of them to come out very nicely.
1. Dry Filament.  I print directly from DryBoxes that are at 10%.  I used this design: https://www.thingiverse.com/thing:4976052
2. Sharp angle on the filament tip when loading.  The 95A will feed through the PTFE tube and first sensor without issue.  Feeding it by very small amounts allows it to make it past the second sensor and get picked up by the feed gear.
3. Used Generic Flex profile and the included CHT nozzle.  My Core One was a kit, so there was also some playing around with the idler screws.  The instructions are a bit vague on what the "factory" setting is.
4. Unloading is a pain as the TPU will form a blob that doesn't want to come out of the top of the extruder (just before the PTFE tube).  It is sometimes possible to open the idler and fish the filament out, cut off the end, then pull it through.  Resist the urge to just pull it out.  The filament will likely snap and leave that blob in the extruder.
5. Clean the extruder and nozzle after each print.  I had a tough time with under extrusion.  The first couple of prints might work great, but without the nozzle cleaning, it would eventually start to under extrude.  Note that I haven't had a successful cold pull on the Core One.  This would probably be the best for cleaning things out.
Hope this helps.
Posted : 08/08/2025 12:42 am
Kieran
(@kieran)
Thank you to All that have posted here.
It is very interesting and I do need to investiage TPU at some point... although the prospect scares the hell out of me as I currently can't get anything priintted that is even halfway 'usable' from my Core One with PETG!
Posted : 11/08/2025 12:53 pm
ssill2
(@ssill2)
I just printed(in pccf) and installed the two modded parts(bogie parts), on my newly upgraded core one and my existing mk4s(that will soon be upgraded).   I believe this will really help things.   I feel like the channel in the bogie part should have been in the original prusa design.   I'm doing a petg print first to make sure normal printing still works on the core one and then maybe tomorrow I'll try some flex again.  I've I've not even attempted ninja flex but I'm well familiar with it's pain since I've gotten it working on MK3, MK4S and 5t xl.   In the XL I had to take the bearing and spring out of the side filament sensors and just disable them.   Some good info here  thanks to all.   I have a second MK4S-CoreOne upgrade kit stting here in the box, but I want to put the first upgraded printer through it's paces before I commit to doing the other one.  I will say already that I don't like how confined things are in the core one.  with the MK4 I can make take the printer out of it's enclosure and get at anything.  The core one is a pain.
Posted : 17/08/2025 8:52 pm
ExtrudingThoughts
(@extrudingthoughts)
This is what is working for me.  I print a lot of TPU and I do a manual filament color change for each print. Yes I've ordered INDX!
I use Overture N95A filament and the Generic Flex Profile with a 0.6mm high flow brass nozzle.  I keep the TPU in an air tight container with an EVA-DRY renewable desiccant when not in use.
Loading: I cut about a 60 degree angle on the filament, usually I can get it past the Core One + first filament sensor without disabling it with the internal toggle switch if I push it hard enough.   Sometimes the Nextruder itself doesn't sense the filament but retracting slightly and pushing it sometimes works or disabling filament sensors always works (I think that option is available after selecting HELP).  Last resort would be disassembling the Nextruder to clean out debris from the filament sensor. ( https://help.prusa3d.com/article/nextruder-filament-sensor-core-one-core-one-l-mk4-s-mk3-9-s-xl_465702)
Core One unloading TPU  in the middle of a print succeeds the first time the majority of the time while unloading from an idle printer fails the majority of the time.  For a filament change in the middle of a print, if the filament did not unload, I select RETRY while pulling on the filament, this always works if I get to the printer quickly.  I don't bother opening the idler in this case.   Before I figured this out I would do multiple retries and the TPU would sometimes go the wrong way around, requiring the planetary gear to be disassembled to fix.
Unloading TPU from an idle (cold) printer works about 10% of the time. When the TPU doesn't unload I quickly go to CONTROL->MOVE AXIS->E/Extruder(I'm doing this from memory so the menu might be different) and rotate the knob clockwise while pulling on the filament. This always works for me.
I print TPU on the textured steel sheet using heavy duty non-scented hairspray for a release layer. This makes removing the print much easier.
I hope this helps.
This post was modified 6 days ago by ExtrudingThoughts
Posted : 30/04/2026 5:03 pm
Once I installed the MK4S Bogie Idler & Main Plate mod and Nextruder Filament Sensor Magnet Mod, top-loading (bypass PTFE) of softer TPU is not an issue. Even without these mods, I don't recall having and issues loading 95A through the Bowden tube.
Posted : 30/04/2026 5:17 pm
HarePrints
(@hareprints)
Hi everyone,
I’ve just completed my first print with TPU 30D and wanted to share a few observations, mainly around filament loading.
Setup: Nextruder + PTFE (Bowden) tube
Issues & findings:
  1. I was not able to push the filament through the PTFE tube while it was connected to the print head.
    What worked was:
    - unscrewing the fitting from the Nextruder
    - removing the elbow connector
    - manually feeding the filament through
    Then I reinstalled the elbow and fitting (without mounting it back onto the Nextruder yet) and manually inserted the filament into the extruder.
  2. The filament started twisting and wrapping around the drive gears.
    Recovery without disassembly:
    - released the tension lever
    - removed the tangled filament
    - used tweezers to guide the filament directly into the hotend path
    - manually advanced the extruder (E axis)
    - re-engaged the tension lever once properly seated
    - continued feeding until extrusion from the nozzle
Plan going forward:
  • Repeat the same loading procedure for soft TPU
  • Print a wing nut for the PTFE fitting to allow tool-free removal
Hope this helps someone working with very soft TPU.
Good luck!
HP
Posted : 05/05/2026 9:32 am
Posted by: @hyiger
Thanks for this sugegstions.  I have had some issues with softer TPU, but not 95A.
I have printed some commercial projects for a company that makes patient lifts.  They want them out of ABS and TPU.  I tend to print the TPU on my Centauri Carbons, but have done several on my Core Ones.  The only failures I had were due to wet filament (I thought).    When I go with softer TPU, I have had additional difficulties.
Posted : 05/05/2026 11:12 am
Conrad
(@conrad-2)
I've printed soft TPE with no problems, but bypassing the PTFE tube is essential. It will fool you because it's not hard to push it through the tube. The problem is that it's much harder to PULL it through the tube and the Nextruder can't do it. It's trivial to take the cover off, pop off the tube and feed from the top, in fact sometimes I just leave the spool on the side and let the stuff just drape up over the edge, though that's probably poor practice.
Posted : 05/05/2026 2:07 pm
Posted by: @conrad-2
This is what I do for TPU and PEBA Air.
Posted : 05/05/2026 3:08 pm
Page 1 / 2
