ASA warping where supports are
MarkLNZ
(@marklnz)
Membre
Hiya, I'm trying to print this in ASA:
https://www.thingiverse.com/thing:6850212
This has a few critical areas that need to be accurate, but also need to be printed off supports, specifically these corners:
I've already printed this in one piece and the above two screen shots show where the part separated from the supports, I used Organic supports with a 0.2mm top contact Z distance.
The larger opening I reckon I can just add a simple mesh/box to bind that corner to the bed & cut the additional block off post print. The smaller opening is problematic though, from what I can see that has to be done via supports as it's 5-10mm inside/below the level so cannot be easily cut off post print, that needs to be accurate as a 'thing' gets plugged into that section and will otherwise flap around.
Bed adhesion isn't a problem - I'm using a Satin sheet with a spray.
I'm using Elegoo ASA filament with the Prusament ASA profile (made adjustments to the density as the Prusa was slightly less dense than the Elegoo) but other than that stock Prusament ASA settings.
Layer height 0.3mm on 0.4mm CHT.
I can't print it face down as the side mounting tabs are slightly raised from the main face and on those mounting tabs are two pins that stick up 3-4mm, there's also a small lip running along the bottom edge.
I have thought about splitting it into two bodies so I can print the front half flat on the bed and the back half front-down so minimal supports are needed,though this would bring a different set of issues I think as there are sections that are not in plane with each other and would require thin/small layers of support material.
Any suggestions about how to approach this?
Thanks.
Publié : 14/02/2026 10:36 pm
RE: ASA warping where supports are
You can try painting on supports in the slicer and using organic (tree) supports.
Also, I wouldn't print both of these at the same time. There is a high probability of the parts curling the sheet off the print bed like a potato chip.
Publié : 15/02/2026 12:12 am
MarkLNZ
(@marklnz)
Membre
Hey thanks for replying, but I don't think you read what my problem is.
Posted by: @marklnz
I already printed this with organic supports, which lead to the printed part warping away from the support material. I'd rather print this in one go but it would mean I have to find a way to prevent the model warping away from the support material.
I wasn't trying to print both of the bodies from the split operation, I was merely pointing out that I was considering splitting the model in two but that this would lead to very thin support required for some sections (the circled in red sections) of the pieces.
Though I didn't state it, I would have printed the two parts individually, that way if one part failed I wouldn't lose a partial other part. But regardless that's great advice from the point of view that they could lift the bed from the heat plate, I hadn't considered that.
Publié : 15/02/2026 7:06 am
Posted by: @marklnz
Posted by: @marklnz
It's surprisingly easy to do with well adhered ASA and PC due to the amount of shrinkage during cooling. For that I use a G10 surface on a rigid steel plate.
Publié : 16/02/2026 2:04 am
