Add PLA lubricant to my print? For noise.
shrap
(@shrap-2)
I am re-working this model of the Zyusouken from Zyuranger. It's turning out very well, so far. I modified the 3 keys to be spring loaded and moveable. I just used some springs I bought at the hardware store.
But... They creak whenever I use them. It works. It's noisy.
I was reading into lubricant I can use on PLA. This particular mechanism works. It's not performing any serious action beyond being a fidget toy. It's just noisy. Refer to the yellow section. I am using a hollow chamber and a plunger that works the spring and keeps the keys in place.
Any ideas on a good lubricant that will work on a spring and PLA? Preferably one that won't change the color of the plastic.
This topic was modified 12 hours ago 2 times by shrap
Posted : 13/10/2025 11:07 pm
K7ZPJ
(@k7zpj)
RE: Add PLA lubricant to my print? For noise.
Aerosol silicone spray will work on PLA and metal.   It won't react with the plastic and it isn't a forever chemical such as PTFE.
Posted : 14/10/2025 12:30 am
John Lindo
(@john-lindo)
Try trumpet piston oil, the finest viscosity produced.
Posted : 14/10/2025 3:20 am
