Z homing error
Bruce Labitt
(@bruce-labitt)
Z homing error
Why did the Z homing give up before reaching the load cell?  For some reason after loading the filament after power up, the bed goes to nearly max Z.  But the homing routine doesn't know this?  This is about the 4th time this has happened to me.  Z homing screen of death fault.  The homing routing faulted before raising the bed to zero.  The bed was only half way up.  But the Homing Z fault claimed is load cell error.  It is not a load cell fault!  The load cell will never actuate if it isn't touched.  Since the bed was never raised to 0, the load cell did not actuate.
So is there a solution for this?  My opinion, this is a bug.
Napsal : 22/01/2026 12:57 am
Bruce Labitt
(@bruce-labitt)
RE: Z homing error
Sorry if I was crabby the other day, but a 30 minute print turned into a 2 hour episode.
Killing the print, and the printer prematurely doesn't seem like a way to foster a good printing experience.  Anyone else run into this kind of issue?  Where the printer gave up before it should?  I understand if it has a problem, it should stop and ask for assistance, but declaring a irreconcilable system fault when there was no need is extreme.  Especially if it requires a full system reset.  That's just not right.
It didn't find the load cell, because it never raised the bed high enough.  I watched the sequence right up to the red screen.  There was nothing from preventing the bed from going up further.  It didn't stall, it just never raised it high enough.
I can speculate that it lost count, or somehow lost it's way, but I don't actually know that.  I do know it gave up and pulled it's own fault.  I think it was premature, because the bed was about 100mm from the top at the time of the Red system fault.
Napsal : 22/01/2026 8:15 pm
mnentwig
(@mnentwig)
RE: Z homing error
maybe read up on "trapezoidal nuts", how to align them, the possibility of lubricating Z-axis spindles. I suspect it's a fairly new printer, and if so the problem tends to improve as the printer is "broken in" (= the Delrin surfaces are worn smooth).
Note, it's not completely a failure mode I've experienced myself so I'm extrapolating, might be wrong.
Napsal : 22/01/2026 8:39 pm
Bruce Labitt
(@bruce-labitt)
RE: Z homing error
I've never heard of needing to lubricate delrin, never mind on trapezoidal nuts.  I don't even know what lubricants are compatible with delrin. To my knowledge, delrin is self lubricating.  The nuts spun relatively easily onto the stepper shafts, as I recall.  Didn't seem sloppy or tight.  I've machined delrin and it's basically slippery.  It doesn't tear, at least not with a sharp tool, or decent injection mold.
The nuts were aligned at assembly, how could they become unaligned?  Why does this fault only happen the first print after powerup, and no other time?
Two of the nuts were from my MK4S, one from the upgrade kit.  Now, I have no idea which is which.  Maybe the new one is tighter?  But the system never faults if I ask it to do Z homing.  Or full xyz homing.  It's always
1. After power up
2. Auto filament load by sticking in filament, without even using the control panel
3. During the print sequence
It's a mystery to me.
Napsal : 22/01/2026 9:05 pm
mnentwig
(@mnentwig)
RE: Z homing error
Well, at the end of the day those nuts may have an issue with friction (arguably from an over-determined geometry, lacking two degrees of freedom to tilt against the print bed). You may be able to resolve it by assembly, lubrication is a possible shortcut (mineral oil should be Delrin-compatible but don't sue me if it turns to dust). If that is the problem in the first place - don't fix it if it ain't broken but it sure is a common problem.
Napsal : 22/01/2026 9:31 pm
Bruce Labitt
(@bruce-labitt)
RE: Z homing error
Posted by: @mnentwig
Suppose you are right about the friction.  I'll try some kind of lube first and report back.
Napsal : 22/01/2026 10:01 pm
mnentwig
(@mnentwig)
Just for the record, I'm not sure whether lubricating the Z-axis rods follows official recommendations (at least when I built the printer they said "do not lubricate").
The downside is, it'll attract dust. But those rods are accessible, nothing a brush couldn't fix IMHO. And it might take only a drop to bridge the time until surfaces are worn smooth from normal operation.
Napsal : 22/01/2026 10:23 pm
Bruce Labitt
(@bruce-labitt)
RE: Z homing error
Reading on various machining forums, the consensus is that Delrin is pretty inert.  One can use oil or grease on it and it doesn't care.  Car people use delrin bushings in suspensions and use grease on them to avoid squeaking.  People use delrin nuts on acme thread lead screws with oil.  White lithium grease is also used.  The biggest problem is just avoiding contamination of other things.  Some use silicone oil.  I wouldn't use silicone oil for this, because it's difficult to remove from surfaces, like a build plate.
Might just try a small drop of a light machine oil and see what happens.
Standard delrin has a low coefficient of friction.  There's a version of delrin that has teflon in it, whose coefficient of friction is even lower.  Basically delrin is a perfect match to this application.
Napsal : 22/01/2026 11:28 pm
RE: Z homing error
Posted by: @bruce-labitt
If you want to have an interesting challenge, try printing Delrin (POM). I’ve successfully printed bushings with it. Wasn’t at all easy (that was the fun part).
Napsal : 23/01/2026 3:54 am
Bruce Labitt
(@bruce-labitt)
RE: Z homing error
No thanks on printing much in the way of exotics.  My printing needs are mundane and generally limited to relatively simple designs or prototypes.  It's more to assist me in making other stuff.  If I need something "strong" I'll make it out of metal, using subtractive technology.  However, often I have found that my plastic printed prototypes are adequate for their use case, so I use them.
That being said, I've yet to make "beautiful" prints, or ones that would be "salable".   Being salable isn't something that matters to me.  I'm not looking to support myself with printing parts or services.
Napsal : 23/01/2026 3:13 pm
mnentwig
(@mnentwig)
Honestly, that's my personal frontier to reality: Producing nice pictures from a flattering angle with a sprinkling of silicon spray (and photoshop if not enough) is one thing. Printing stuff that actually looks good as a physical object... not convinced. And I'm one of the few MMU users with 0.25mm nozzle, for that very reason.
ABS vapor smoothing might be one option I'd investigate for shiny surfaces. Grinding paper works with ASA for silky finish but the amount of work - especially for complex parts - is overwhelming (yes, I could invest in more efficient tools but it would still be mainly "3d-printing-assisted craftsmanship". And this starts already with support removal).
Maybe reality has failed to catch up with the marketing narrative. But whatever, for what it can do, FDM 3D printing is amazing...
Napsal : 23/01/2026 3:53 pm
Bruce Labitt
(@bruce-labitt)
RE: Z homing error
I agree that FDM printing is amazing.
But those layer lines, and occasional artifacts, make it tough to achieve aesthetic beauty, at least in my opinion.  (It takes a lot of work to smooth out those features AND preserve any detail.)  I want to try lost PLA casting some time, which, believe me, comes with a lot of requirements, and I know those layer lines will be in the cast.  Maybe when it warms up I'll try getting that to work.  I don't even have an oven yet to burn out the PLA.  Still in the study phase, otherwise known as, "What's the least expensive way to do this and have it work mode?"
FDM is very good for somethings, not so good for others.  Pretty much like many technologies.  Investment casting is great for fine detail, but time intensive, and requires capital outlay for melting and burnout of the PLA.
Napsal : 23/01/2026 4:15 pm
mnentwig
(@mnentwig)
RE: Z homing error
you might try ordinary sandcasting (two shells with sticky casting sand, where you remove the template before pouring in metal).
I've seen that in action once with a plain gas torch, a crucible from the hobby shop and scrap metal brass as material, copying RC car differential wheels. It looked easy enough. In the hands of a trained toolsmith 🙂
Napsal : 23/01/2026 5:15 pm
Bruce Labitt
(@bruce-labitt)
RE: Z homing error
I don't think one can get enough detail using sand casting.  Need a good finish to be able to use the part in question.  It has places for o-ring seals.  If I have to post machine it, I might as well machine it from the beginning.  (And I don't want to do that, as it's kind of complicated.)  Plastic is not adequate for the application, as there are relatively small area with large forces on it.  The original piece was plastic, and I see the contact points, and the wear, in only two days of use.  Which was why I was considering casting it in Zamak2.
I can do the melt, with a torch and graphite crucible.  Have that.  The PLA burnout requires pretty high temperatures to reduce it to ash.  That needs to be a controlled process, (an oven with temperature ramping) or the mold can crack.
I copied the part by eye and calipers and made a CAD model.  It took several refinements before I got a print that was functional.  There were several contact surfaces which were important to the design, and I had to discover them by trial and error, because there's no existent documentation, for a part that was last manufactured 40 years ago.  But my PLA print using natural PLA with a 0.25mm nozzle came out well.
It's a bolt for an old airgun (4.5mm 0.177").  The PLA functions in the airgun, but I don't think it will have a long lifetime there.  One day, I will cast it in zamak2, an easy to cast zinc alloy.  Zamak should be strong enough, as the airgun body itself is made from it.
Napsal : 23/01/2026 5:55 pm
1 lidem se líbí
