Z axis test failed
Wim
 Wim
(@wim-3)
Z axis test failed
Im currently going to the calibartion process and it fails at the Z axis test.
It then reboots and gives a red screen with error.
Any tips where i should look at?  The nozzle is pressed all the way up.
Napsal : 31/05/2025 11:58 am
Wim
 Wim
(@wim-3)
RE: Z axis test failed
resolving my own problem. Lowering the nozzle 1 mm did solve the problem
Napsal : 31/05/2025 12:15 pm
Wim
 Wim
(@wim-3)
follow up.   When starting a print i got the bed level failed error.   I solved this again by lowering the nozzle. You can see the copper part now for about 5mm.
would this create further problems ? (cooling is a bit wrongly placed now)
Napsal : 01/06/2025 5:59 am
you might get Loading issues as the filament feed tube will be lower  than normal
Joan
Napsal : 01/06/2025 7:11 am
Wim
 Wim
(@wim-3)
I dont understand it though. That loadcell is factory placed on the metal cooling element.  How can it be triggered when the nozzle is higher up?
This post was modified před 1 month by Wim
Napsal : 01/06/2025 7:55 am
Hi Wim,
the load cell responds to vertical displacement
so whether the nozzle is at the normal height, or artificially lower,  pressure on the end of the nozzle will still act vertically
I don't have a core one, so I have no idea why your printer doesn't work with the nozzle in the normal position, is something stopping the build plate reaching the nozzle?
Napsal : 01/06/2025 11:33 am
gb160
(@gb160)
The nozzle definitely shouldn't be that low, you should only see a tiny bit of copper.
Get onto Prusa support/Chat...they'll get you sorted.
Napsal : 01/06/2025 11:43 am
Raaz
 Raaz
(@raaz-2)
Can you upload a picture of the rear corner with the cable cover of the print bed? Maybe your fan duct is hitting the cover.
Napsal : 01/06/2025 8:48 pm
Elmo
 Elmo
(@elmo-2)
Change the position of the wire from the filament sensor. It should be behind the pte tube
This post was modified před 1 month by Elmo
Napsal : 02/06/2025 2:36 pm
1 lidem se líbí
Wim
 Wim
(@wim-3)
Problem solved. I installed the z screw's upside down....  Sometimes i need more coffee...
Napsal : 03/06/2025 9:35 am
2 lidem se líbí
