Where to find images from the Buddy3D camera
Artnow
(@artnow)
Hello, it's been 10 days since I installed my Prusa Core One, with the Buddy3D camera, I added an SD card, I can see the images in the Prusa Connect interface every 20-30 seconds, but I don't know where to find the images made during printing, to see the time lapse? Thank you for your help.
Postato : 20/04/2025 6:12 am
James Kirk
(@james-kirk)
RE: Where to find images from the Buddy3D camera
There are no pictured stored and there is no timelapse function.
Postato : 20/04/2025 4:47 pm
Harry39Haywood
(@harry39haywood)
Utenti
Hello!
The Buddy3D camera on your Prusa Core One connected to Prusa Connect provides periodic snapshots for monitoring, not a saved time-lapse video. The camera's SD card is for firmware recovery, not image storage. To create time-lapses, you'd currently need to explore third-party solutions involving additional hardware like a Raspberry Pi and software like OctoPrint, as Prusa Connect doesn't have a built-in time-lapse saving feature for the Buddy3D camera. Keep an eye on Prusa Research for potential future updates to Prusa Connect.
MyACUVUE Rewards
Postato : 21/04/2025 9:33 am
Is it just me, or is the Buddy3D camera disappointing in almost every respect? Requires a separate WiFi connection and can't be used via Ethernet; requires PrusaConnect to view; delivers one frame every x seconds; black & white images only; can't store time-lapse images despite the built-in SD card slot.
Even if this was a rushed development to enable Prusa to "check the box" on the spec sheet, I would have expected something a bit more useful. Is there anything they implemented properly in this camera?
Postato : 21/04/2025 10:02 am
4 persone hanno apprezzato
Rainer
(@rainer-2)
That's why I also installed an Esp32 cam in the Core One.
It has already proven itself in the MK4.
I designed the housing for it myself. The Esp32 cam is available for little money and the firmware is now fully developed.
Postato : 21/04/2025 11:20 am
3 persone hanno apprezzato
WorstCase
(@worstcase)
I am very disappointed by the Buddy3d Camera too.
The image quality is ok, but I get an image every 5-15 seconds or sometimes the printer goes "offline" while printing and then delivers no more images at all. Black and white is okey, but I feel this should have been mentioned on the product-page before ordering.
Postato : 27/04/2025 2:46 pm
1 persone hanno apprezzato
gb160
(@gb160)
My Core One camera once went colour for around 20 seconds when the clouds were moving and sunlight shone directly on the core one.
It was a beautiful moment, I’ll remember those 20 second (2 entire frames) for the rest of my life.
Postato : 30/04/2025 8:46 pm
N3XT3D
(@n3xt3d)
I noticed that the camera switches to a color image if you have a light background with a larger area.
You can test this by holding a large, white sheet of paper in the printer. You can then hear the camera click when it switches back from night vision and vice versa.
You will then also have a colored image. At least for a moment 😆
Postato : 01/05/2025 11:30 am
WorstCase
(@worstcase)
So where do we order a white textured steel sheet? 😉
Postato : 04/05/2025 3:30 pm
Borreltje
(@borreltje)
Posted by: @n3xt3d
The click implies a relay, so maybe we can short the relay contacts? I will have a look if I can get the relay to always connect, or maybe bypass the light sensor.
Postato : 04/05/2025 4:55 pm
gb160
(@gb160)
Posted by: @borreltje-2
The relay closing/opening will just be power to the IR LEDs, there may well be a way of changing the mode but I doubt the relay plays any part... playing around with the photoresistor circuit will be the way to 'hack' it. I would've thought the LEDs on the light bar in the printer would provide enough light for the camera to deliver an acceptable image/images in colour.
I really can't fathom why it's taken this long to release a firmware fix to either better gauge the light level or to let the user set their own custom level...wishful thinking but maybe they're trying to fix everything in one hit (local live streaming at an acceptable refresh rate + better IR switching levels)
Postato : 05/05/2025 6:19 am
