					                		VFA Artifacts on X+Y Straight Edges - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/vfa-artifacts-on-xy-straight-edges/</link>
                <lastBuildDate>Sat, 11 Apr 2026 20:44:40 +0000</lastBuildDate>
                        <title>RE: VFA Artifacts on X+Y Straight Edges</title>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/vfa-artifacts-on-xy-straight-edges/paged/65/#post-787504</link>
                        <pubDate>Thu, 26 Mar 2026 22:26:37 +0000</pubDate>
                        <description><![CDATA[Posted by: @adaddison Question, for those of you that upgraded to GT1.5 belts, what belt tension are you running on them?Using the new belt tuning wizard, I tuned the belts to 87Hz and 83.5H...]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="595407" data-postid="764528" data-mention="adaddison"><div class="wpforo-post-quote-author"><strong> Posted by: @adaddison </strong></div><p>Question, for those of you that upgraded to GT1.5 belts, what belt tension are you running on them?</p></blockquote><p>Using the new belt tuning wizard, I tuned the belts to <strong>87Hz</strong> and <strong>83.5Hz</strong> for the top and bottom belts, respectively, and the printer moves very comfortably.  Initially I kept the frequencies the same as on the stock belts, but I got some strange creaking that made me think they were too tight.  Then I noticed that my 1.5gt belts were thicker than the stock, so, assuming they're made of the same stuff, getting the same <em>tension</em> on thicker belts would require <em>lower</em> frequencies.  I measured the mass per length of belt for both the stock and the new belts and calculated the following:</p><p>Stock belts: 7.349g/m<br />1.5gt belts: 8.952g/m<br />Frequency scale: sqrt(7.349 / 8.952) ≈ 90.6% of the original frequencies.</p><p>Top belt: 96Hz * 0.906 = 86.976Hz<br />Bottom belt: 92Hz * 0.906 = 83.352Hz</p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>fosterish</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/vfa-artifacts-on-xy-straight-edges/paged/65/#post-787504</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/vfa-artifacts-on-xy-straight-edges/paged/65/#post-787036</link>
                        <pubDate>Mon, 23 Mar 2026 16:16:24 +0000</pubDate>
                        <description><![CDATA[I&#039;ve made the 1.5gt switch, and seen a significant change in VFAs.  It&#039;s important to note (as several have) that this is not a silver bullet fix, but rather a mitigation that is effective d...]]></description>
                        <content:encoded><![CDATA[<p>I've made the 1.5gt switch, and seen a significant <em>change</em> in VFAs.  It's important to note (as several have) that this is not a silver bullet fix, but rather a mitigation that is effective during normal printer use.  Specifically, 1.5gt belts shift the "bad" speeds <em>lower</em>, which leaves a greater range of faster speeds for printing relatively VFA-free.  Also, the amplitude and the period of the artifact ripple itself is smaller (smaller pitch, smaller teeth -&gt; smaller artifacts).</p>
<p>However, it is very important that anyone doing this mod knows how they'll have to adjust the software to compensate for the differently sized pulleys.  The conventional wisdom is to utter the "M92 98.44 98.44" magic incantation at the beginning of your gcode.  It seems that people have just accepted this as necessary, and indeed it does work (despite leaving your printer in a weird state afterwards), but unfortunately <em><strong>it makes no sense</strong></em><em>.</em>  The new pulleys are slightly smaller than the stock, and so they need to rotate <em>more</em> (take <em>more</em> steps per mm) to cover the same ground.  The only explanation is a firmware bug.</p>
<p>To that end, I have a PR up that discusses the problem in more detail, and provides a fix for anyone who's comfortable building/flashing their own firmware: https://github.com/prusa3d/Prusa-Firmware-Buddy/pull/5062</p>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/vfa-artifacts-on-xy-straight-edges/paged/65/#post-787036</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/vfa-artifacts-on-xy-straight-edges/paged/65/#post-786138</link>
                        <pubDate>Tue, 17 Mar 2026 12:15:07 +0000</pubDate>
                        <description><![CDATA[Oh, this post comes at just the right time!I’m currently experimenting with high-temperature settings on my Core One using PPS, PPA, and maybe even PEI, so VFA isn’t too much of a problem wi...]]></description>
                        <content:encoded><![CDATA[<p>Oh, this post comes at just the right time!</p><p>I’m currently experimenting with high-temperature settings on my Core One using PPS, PPA, and maybe even PEI, so VFA isn’t too much of a problem with the parts I’m printing.</p><p>But:I’ve ordered some 1.5GT parts from Asia so I can finally get rid of the VFA when I print with glossy filament again.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>jan.d.slay</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/vfa-artifacts-on-xy-straight-edges/paged/65/#post-786138</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/vfa-artifacts-on-xy-straight-edges/paged/65/#post-786123</link>
                        <pubDate>Tue, 17 Mar 2026 09:44:08 +0000</pubDate>
                        <description><![CDATA[Did you mix up the thread? Here we are talking about CORE One, not MK3.]]></description>
                        <content:encoded><![CDATA[<p>Did you mix up the thread? Here we are talking about CORE One, not MK3.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>miroslav.h4</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/vfa-artifacts-on-xy-straight-edges/paged/65/#post-786123</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/vfa-artifacts-on-xy-straight-edges/paged/65/#post-786098</link>
                        <pubDate>Tue, 17 Mar 2026 05:57:40 +0000</pubDate>
                        <description><![CDATA[Has anyone moved from ball bearings to poly bearings and tested?I am about to upgrade from 3s+ to 3.5+ and changing to poly bearings at the same time.My small tests say that they are much be...]]></description>
                        <content:encoded><![CDATA[<p>Has anyone moved from ball bearings to poly bearings and tested?</p><p>I am about to upgrade from 3s+ to 3.5+ and changing to poly bearings at the same time.</p><p>My small tests say that they are much better.</p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Robin_13</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/vfa-artifacts-on-xy-straight-edges/paged/65/#post-786098</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/vfa-artifacts-on-xy-straight-edges/paged/65/#post-765266</link>
                        <pubDate>Mon, 22 Sep 2025 16:01:32 +0000</pubDate>
                        <description><![CDATA[Hello, first time user here with a core one kit on the way.Looking at the VFA in the video didn&#039;t bother me, have been getting those for about half a year on my first printer (ad5m pro). Had...]]></description>
                        <content:encoded><![CDATA[<p>Hello, first time user here with a core one kit on the way.</p><p>Looking at the VFA in the video didn't bother me, have been getting those for about half a year on my first printer (ad5m pro). Had no idea those were bad, the ones I get aren't terrible but really noticeable on shiny filament.</p><p>As for the belt fix, would upgrading to 1.5mm belts need new drivers?</p><p>I've seen mixed reviews on the VFA, with a lot of people stating perfect quality on their core ones and lots saying they have terrible issues. I haven't seen any reviews on the software update they released earlier this month to fix VFAs, has anyone here seen better results with this?</p><p>Thanks.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Wario Man</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/vfa-artifacts-on-xy-straight-edges/paged/65/#post-765266</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/vfa-artifacts-on-xy-straight-edges/paged/64/#post-765234</link>
                        <pubDate>Mon, 22 Sep 2025 07:04:10 +0000</pubDate>
                        <description><![CDATA[What changes need to be made to the firmware and how?]]></description>
                        <content:encoded><![CDATA[<p>What changes need to be made to the firmware and how?</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>gringo</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/vfa-artifacts-on-xy-straight-edges/paged/64/#post-765234</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/vfa-artifacts-on-xy-straight-edges/paged/64/#post-764940</link>
                        <pubDate>Fri, 19 Sep 2025 08:27:35 +0000</pubDate>
                        <description><![CDATA[Posted by: @adaddison Question, for those of you that upgraded to GT1.5 belts, what belt tension are you running on them?Between 80Hz and 85Hz on both belt with the old method.Works like a C...]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="595407" data-postid="764528" data-mention="adaddison"><div class="wpforo-post-quote-author"><strong> Posted by: @adaddison </strong></div><p>Question, for those of you that upgraded to GT1.5 belts, what belt tension are you running on them?</p></blockquote><p>Between 80Hz and 85Hz on both belt with the old method.<br />Works like a Charm. Almost no VFA.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>xzess</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/vfa-artifacts-on-xy-straight-edges/paged/64/#post-764940</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/vfa-artifacts-on-xy-straight-edges/paged/64/#post-764929</link>
                        <pubDate>Fri, 19 Sep 2025 01:31:38 +0000</pubDate>
                        <description><![CDATA[That wouldn&#039;t surprise me.  I was calibrating some FR PC/ABS, and had slowed the MVF to 6, to try and improve quality.  It had printed the ezPC beautifully, but needed some work with the FR ...]]></description>
                        <content:encoded><![CDATA[<p>That wouldn't surprise me.  I was calibrating some FR PC/ABS, and had slowed the MVF to 6, to try and improve quality.  It had printed the ezPC beautifully, but needed some work with the FR blend.  If I'm able to get the fan settings tuned and get the corner details looking right, I'll speed it back up.  It does support the claim that a big piece of this belt ripple problem is connected to speed. </p><p>-J</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>TeamD3dp</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/vfa-artifacts-on-xy-straight-edges/paged/64/#post-764929</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/vfa-artifacts-on-xy-straight-edges/paged/64/#post-764915</link>
                        <pubDate>Thu, 18 Sep 2025 22:47:25 +0000</pubDate>
                        <description><![CDATA[Posted by: @teamd3dp Interesting discovery for me today while running a PA calibration on our Qidi Q2 at work...I see prominent belt ripple along the pure X movements.  🤔.   Granted this isn...]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="534582" data-postid="764912" data-mention="teamd3dp"><div class="wpforo-post-quote-author"><strong> Posted by: @teamd3dp </strong></div><p>Interesting discovery for me today while running a PA calibration on our Qidi Q2 at work...I see prominent belt ripple along the pure X movements.  🤔.   Granted this isn't a VFA test, but so far I'd seen only very smooth walls from this printer.</p><p>-J</p></blockquote><p>I think Qidi use speed exclusion zones in their slicer profiles to avoid belt ripple problem speeds - the PA test might have overridden that? </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Jondoe</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/vfa-artifacts-on-xy-straight-edges/paged/64/#post-764915</guid>
