The extruder rotates in the wrong direction when the filament is to be loaded.
Necon
(@necon)
Extruder dircetion wrong
What i am doing wrong ?
Opublikowany : 01/03/2026 12:20 pm
RE: The extruder rotates in the wrong direction when the filament is to be loaded.
What kind of Core One? Did you purchase assembled or is it a kit? Try running the filament sensor calibrations.
Opublikowany : 01/03/2026 4:17 pm
Necon
(@necon)
Hey its the assamble kit. I checked the wires and everything. The filament sensor calibration is running without problems. Its not the sensor, is it possible that the phases of the extruder motor were reversed? That would be my idea.
Opublikowany : 01/03/2026 5:03 pm
Jan
 Jan
(@jan-21)
i have the same issue. The Core One is from March 2025 and is factory assembled. It is not from the first series. I´m the second owner. The old owner hast in the past the same issue but found no solution. The Prusa Support chat give that to an technician. All cabels are original and no changes on the poles. The Motor is the original one. We have checked that with photos and videos in coworking with Prusa. I´m waiting for an solution and will be post that here.
greeting, Jan
Opublikowany : 02/03/2026 12:03 pm
ssmith
(@ssmith)
Check that the side filament sensor works correctly. If the extruder sensor sees filament but the side sensor does not, the printer assumes that the filament in between needs to be ejected. Another approach is to disable the side sensor setting.
Opublikowany : 02/03/2026 7:17 pm
1 ludzie polubili
Same Old Shane
(@same-old-shane)
Member Admin
Well I can add to the list of things to check 🙂
do a factory reset of the printer and select hard reset.
https://help.prusa3d.com/article/factory-reset-core-one-l-core-one-mk4-s-mk3-9-s-mk3-5-s-mini-xl_421206
Redo the calibration and do not skip the motor calibration (not saying you did).
Check the flow of the motor.
If it still continues, pop off the love board cover on the extruder, take a few photos of the cable connections and take the video you have here and contact support so they can go over things and go from there.
Shane (AKA FromPrusa)
Opublikowany : 02/03/2026 11:48 pm
Necon
(@necon)
Hey, I wrote with the support and we think the phases of the motor is switch. So they will send me a new one and I will see if this will fix it =)
Opublikowany : 03/03/2026 6:18 am
Posted by: @ssmith
This is the likely cause. The video in the original post shows the display in passing. The extruder filament sensor is ON while the side filament sensor is OFF.
Opublikowany : 03/03/2026 6:31 am
1 ludzie polubili
