Power issues
8bitHero
(@8bithero)
Mitglied
Power issues
I have a brand new assembled Core One purchased from Printed Solid. I turned it off. Unplugged it. Plugged it back in and then there is no power. I checked the fuse and the fuse is good. It is the same cable and the same outlet I was using before. There is just no power.
If someone has seen this and has a solution besides waiting for Printed Solid's support I would greatly appreciate it. This is incredibly frustrating.
Dieses Thema wurde geändert Vor 5 days von 8bitHero
Veröffentlicht : 11/09/2025 7:22 pm
RE: Power issues
Have you tried a different mains cable? I had a bad one with my MK4 and had to replace it.
Veröffentlicht : 12/09/2025 1:46 am
RE: Power issues
Either that or the power supply is faulty. If you have a multimeter can see if you measure 24VDC across the terminals
Veröffentlicht : 12/09/2025 1:56 am
miroslav.h4
(@miroslav-h4)
In the second image, the main switch is in the 'Off' position. Try turning it "On" position. 😀 😀
Diese r Beitrag wurde geändert Vor 5 days von miroslav.h4
Veröffentlicht : 12/09/2025 8:56 am
8bitHero
(@8bithero)
Mitglied
RE: Power issues
I wish it was that simple. I did some troubleshooting with support and I have a dead PSU. I am being sent a new one.
Veröffentlicht : 12/09/2025 12:29 pm
