PID Calibration on the Core One
Derek Austin
(@derek-austin)
Is it possible to carry out an PID Calibration on the Core One using Autotune as it does not appear in the LCD Menu?
Posted : 19/10/2025 1:25 pm
You can run PID calibration however it has to be done by sending g-code to the printer. You will need to connect to your computer to the printer over the serial USB-C port in the back,  open a terminal like putty, screen, cool term etc. And send the g-code command to initiate PID calibration: M303 S250 (sets hot end target to 250C). When it completes you will see (for example):
 Classic PID
 Kp: 30.77 Ki: 2.87 Kd: 82.45
PID Autotune finished! Put the last Kp, Ki and Kd constants from below into Configuration.h
#define DEFAULT_Kp 30.77
#define DEFAULT_Ki 2.87
#define DEFAULT_Kd 82.45
You will then need to add these to the custom g-code section of your printer under Start G-code as (again for example) since there is no facility to store this in the firmware.
M17 ; enable steppers
M862.1 P[nozzle_diameter] A{(filament_abrasive[0] ? 1 : 0)} F{(nozzle_high_flow[0] ? 1 : 0)} ; nozzle check
M862.3 P "COREONE" ; printer model check
M862.5 P2 ; g-code level check
M862.6 P"Input shaper" ; FW feature check
M115 U6.3.4+10511
; Calibrated PID
M301 P30.77 I2.87 D76.09
This post was modified 12 hours ago 2 times by hyiger
Posted : 19/10/2025 7:06 pm
RE: PID Calibration on the Core One
Another way to connect to the C1 is via OctoPrint which is what I use. It works best if you have a RaspberryPi.
Posted : 19/10/2025 7:17 pm
