					                		Nozzle cleaning fail - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/nozzle-cleaning-fail-2/</link>
                <lastBuildDate>Fri, 12 Jun 2026 10:52:53 +0000</lastBuildDate>
                        <title>RE: Nozzle cleaning fail</title>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/nozzle-cleaning-fail-2/paged/2/#post-790012</link>
                        <pubDate>Tue, 21 Apr 2026 15:53:06 +0000</pubDate>
                        <description><![CDATA[Posted by: @gezz I was similarly frustrated with this issue thinking I would need to pull down and clean the extruder, I did a number of cold pulls (very simple using the inbuilt software ) ...]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="586962" data-postid="790011" data-mention="gezz"><div class="wpforo-post-quote-author"><strong> Posted by: @gezz </strong></div><p>I was similarly frustrated with this issue thinking I would need to pull down and clean the extruder, I did a number of cold pulls (very simple using the inbuilt software ) and this solved my issue. Also new firmware was updated.  Hope this helps .....</p><p>NB I tried an assortment of remedies but the above has worked ........</p></blockquote><p>Usually I use a brass brush to remove debris from the nozzle head. That generally works for me. Also, a nozzle wiper mod will help versus smooshing the nozzle against the sheet. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/nozzle-cleaning-fail-2/paged/2/#post-790012</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/nozzle-cleaning-fail-2/paged/2/#post-790011</link>
                        <pubDate>Tue, 21 Apr 2026 15:50:25 +0000</pubDate>
                        <description><![CDATA[I was similarly frustrated with this issue thinking I would need to pull down and clean the extruder, I did a number of cold pulls (very simple using the inbuilt software ) and this solved m...]]></description>
                        <content:encoded><![CDATA[<p>I was similarly frustrated with this issue thinking I would need to pull down and clean the extruder, I did a number of cold pulls (very simple using the inbuilt software ) and this solved my issue. Also new firmware was updated.  Hope this helps .....</p><p>NB I tried an assortment of remedies but the above has worked ........</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Gezz</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/nozzle-cleaning-fail-2/paged/2/#post-790011</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/nozzle-cleaning-fail-2/#post-789962</link>
                        <pubDate>Tue, 21 Apr 2026 10:15:02 +0000</pubDate>
                        <description><![CDATA[I often have nozzle cleaning fails, and I see the printhead hovering around 70mm over the bed for a while before giving the error message. ususally works on retry but I have to babysit the p...]]></description>
                        <content:encoded><![CDATA[<p>I often have nozzle cleaning fails, and I see the printhead hovering around 70mm over the bed for a while before giving the error message. ususally works on retry but I have to babysit the printer. Could this be a load cell failure thinking it has already hit the bed ? </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Flutelab</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/nozzle-cleaning-fail-2/#post-789962</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/nozzle-cleaning-fail-2/#post-779604</link>
                        <pubDate>Sun, 25 Jan 2026 15:43:04 +0000</pubDate>
                        <description><![CDATA[In PrusaSlicer switch to Expert mode. Then in Printers -&gt; Custom G-code -&gt; Start G-code look for G29 P9 X208 Y-2.5 W32 H4 and add a &#039;;&#039; to comment it out. You should only do this if yo...]]></description>
                        <content:encoded><![CDATA[<p>In PrusaSlicer switch to Expert mode. Then in Printers -&gt; Custom G-code -&gt; Start G-code look for G29 P9 X208 Y-2.5 W32 H4 and add a ';' to comment it out. You should only do this if you install a nozzle wiper. Otherwise the bed mesh could be inaccurate due to filament stuck to the nozzle and could possibly cause first layer adhesion problems. </p>
<pre contenteditable="false">;G29 P9 X208 Y-2.5 W32 H4</pre>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/nozzle-cleaning-fail-2/#post-779604</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/nozzle-cleaning-fail-2/#post-779514</link>
                        <pubDate>Sat, 24 Jan 2026 21:13:58 +0000</pubDate>
                        <description><![CDATA[And how do I disable the nozzle-Cleaning G-Code?]]></description>
                        <content:encoded><![CDATA[<p>And how do I disable the nozzle-Cleaning G-Code? </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Norbert</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/nozzle-cleaning-fail-2/#post-779514</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/nozzle-cleaning-fail-2/#post-779512</link>
                        <pubDate>Sat, 24 Jan 2026 21:02:42 +0000</pubDate>
                        <description><![CDATA[I would recommend printing a nozzle wiper and disable the nozzle cleaning g-code.]]></description>
                        <content:encoded><![CDATA[<p>I would recommend printing a nozzle wiper and disable the nozzle cleaning g-code. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/nozzle-cleaning-fail-2/#post-779512</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/nozzle-cleaning-fail-2/#post-779459</link>
                        <pubDate>Sat, 24 Jan 2026 10:27:45 +0000</pubDate>
                        <description><![CDATA[Posted by: @nessuno0505 Firmware 6.4.0, nozzle cleaning more reliable when printing PETG, but unreliable with Varioshore TPU, standard Prusa profile.The varioshore TPU always oozes a bit at ...]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="86887" data-postid="775621" data-mention="nessuno0505"><div class="wpforo-post-quote-author"><strong> Posted by: @nessuno0505 </strong></div><p>Firmware 6.4.0, nozzle cleaning more reliable when printing PETG, but unreliable with Varioshore TPU, standard Prusa profile.</p><p>The varioshore TPU always oozes a bit at 210-220°C, so the nozzle cant't be 100% clean! If I let the cleaning nozzle fail and then choose "ignore", the printer prints flawlessly without issues.</p><p>What is the purpose of the nozzle cleaning? It's not a cleaning by the way: the nozzle touches the bed a few times, it's not a good method to "clean" IMHO.</p><p>I know there are mods and g-code lines to add to have a proper "cleaning", but the prints are good even if I skip the cleaning (at least with varioshore TPU), so why bother to clean?</p><p>Nevertheless I'd like to know more about this... bug? Is this a bug?</p><p>Thanks.</p></blockquote><p>For me it's the same. I tried all tips but now I simply ignore the error and it prints perfect. I'd like to skip the whole nozzle cleaning nonsense.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/nozzle-cleaning-fail-2/#post-779459</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/nozzle-cleaning-fail-2/#post-775621</link>
                        <pubDate>Fri, 26 Dec 2025 20:20:08 +0000</pubDate>
                        <description><![CDATA[Firmware 6.4.0, nozzle cleaning more reliable when printing PETG, but unreliable with Varioshore TPU, standard Prusa profile.The varioshore TPU always oozes a bit at 210-220°C, so the nozzle...]]></description>
                        <content:encoded><![CDATA[<p>Firmware 6.4.0, nozzle cleaning more reliable when printing PETG, but unreliable with Varioshore TPU, standard Prusa profile.</p><p>The varioshore TPU always oozes a bit at 210-220°C, so the nozzle cant't be 100% clean! If I let the cleaning nozzle fail and then choose "ignore", the printer prints flawlessly without issues.</p><p>What is the purpose of the nozzle cleaning? It's not a cleaning by the way: the nozzle touches the bed a few times, it's not a good method to "clean" IMHO.</p><p>I know there are mods and g-code lines to add to have a proper "cleaning", but the prints are good even if I skip the cleaning (at least with varioshore TPU), so why bother to clean?</p><p>Nevertheless I'd like to know more about this... bug? Is this a bug?</p><p>Thanks.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Nessuno0505</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/nozzle-cleaning-fail-2/#post-775621</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/nozzle-cleaning-fail-2/#post-775395</link>
                        <pubDate>Tue, 23 Dec 2025 22:03:36 +0000</pubDate>
                        <description><![CDATA[I was having nozzle cleaning failures. I could clean the nozzle and it might work, but then the bed probing would fail. Support is sending me a new main cable. In the meantime, I found this ...]]></description>
                        <content:encoded><![CDATA[<p>I was having nozzle cleaning failures. I could clean the nozzle and it might work, but then the bed probing would fail. Support is sending me a new main cable. <br /><br />In the meantime, I found this thread on github https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/4596<br /><br />In it there is a user suggesting that the heater is inducing current and causing a disruption on the loadcell signal. The solution is to remove the main cable, depin the heater wires from the connector, create twisted pairs, and re-insert the pins into the connector (be mindful of polarity). <br /><br />I did this, and now my printer that was a paperweight is happily printing again. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Krieger</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/nozzle-cleaning-fail-2/#post-775395</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/nozzle-cleaning-fail-2/#post-755028</link>
                        <pubDate>Sun, 22 Jun 2025 12:33:16 +0000</pubDate>
                        <description><![CDATA[Turn power back on and home the printer. Note: Not Z homing.*calibration.Z-homing happens at every start of a print, when the bed moves against the nozzle. Calibration is when the bed is mov...]]></description>
                        <content:encoded><![CDATA[<blockquote data-userid="0" data-postid="755021" data-mention=""><p>Turn power back on and home the printer. Note: Not Z homing.</p></blockquote><p>*calibration.</p><p>Z-homing happens at every start of a print, when the bed moves against the nozzle. Calibration is when the bed is moved against the bottom with a lot of noise.</p><p>Not meant as being a smarta**, I just confused the two things myself so want to clarify. </p><p>If you want to permanently fix this, there are mods for the bottom of the Core One to level the bed during Z-calibration. Not sure that's time well spent, but there are nice dust/filament-pieces cover combinations. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Raaz</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/nozzle-cleaning-fail-2/#post-755028</guid>
