					                		Noise after belt tensioning (damaged bearing?) - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/noise-after-belt-tensioning-damaged-bearing/</link>
                <lastBuildDate>Fri, 06 Mar 2026 08:17:11 +0000</lastBuildDate>
                        <title>RE: Noise after belt tensioning (damaged bearing?)</title>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/noise-after-belt-tensioning-damaged-bearing/#post-741343</link>
                        <pubDate>Thu, 20 Mar 2025 15:25:20 +0000</pubDate>
                        <description><![CDATA[I&#039;ve replaced the X-axis motor today. Here is how you easily reinstall the pulley on the new motor:]]></description>
                        <content:encoded><![CDATA[<p>I've replaced the X-axis motor today. Here is how you easily reinstall the pulley on the new motor: https://www.printables.com/model/1236389-core-one-x-axisy-axis-motor-pulley-assembly-tool</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>cryptomilk</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/noise-after-belt-tensioning-damaged-bearing/#post-741343</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/noise-after-belt-tensioning-damaged-bearing/#post-740819</link>
                        <pubDate>Mon, 17 Mar 2025 13:10:04 +0000</pubDate>
                        <description><![CDATA[A replacement is already on the way from Prusa.]]></description>
                        <content:encoded><![CDATA[<p>A replacement is already on the way from Prusa.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/noise-after-belt-tensioning-damaged-bearing/#post-740819</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/noise-after-belt-tensioning-damaged-bearing/#post-740812</link>
                        <pubDate>Mon, 17 Mar 2025 12:49:35 +0000</pubDate>
                        <description><![CDATA[I can&#039;t read your video, but if you&#039;re sure it comes from a motor, try to reach Prusa support to ask for a replacement. :)]]></description>
                        <content:encoded><![CDATA[<p>I can't read your video, but if you're sure it comes from a motor, try to reach Prusa support to ask for a replacement. :)</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Scott</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/noise-after-belt-tensioning-damaged-bearing/#post-740812</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/noise-after-belt-tensioning-damaged-bearing/#post-740799</link>
                        <pubDate>Mon, 17 Mar 2025 11:13:02 +0000</pubDate>
                        <description><![CDATA[It&#039;s the X axis motor :-(
&nbsp;1f809428-x-motor-sound.mp4]]></description>
                        <content:encoded><![CDATA[<p>It's the X axis motor :-(</p>
<div id="wpfa-175161" class="wpforo-attached-file"><a class="wpforo-default-attachment" href="//storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/wpforo/default_attachments/1742209983-1f809428-x-motor-sound.mp4" target="_blank" title="1f809428-x-motor-sound.mp4"><i class="fas fa-paperclip"></i>&nbsp;1f809428-x-motor-sound.mp4</a></div>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/noise-after-belt-tensioning-damaged-bearing/#post-740799</guid>
                        <title>Noise after belt tensioning (damaged bearing?)</title>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/noise-after-belt-tensioning-damaged-bearing/#post-740724</link>
                        <pubDate>Sun, 16 Mar 2025 16:45:22 +0000</pubDate>
                        <description><![CDATA[As some prints where off today, I checked the belt tension and it was way to low (~70 Hz). So I tightened up the belts and tuned them back to 85 Hz. Now I have a strange noise which sounds l...]]></description>
                        <content:encoded><![CDATA[<p>As some prints where off today, I checked the belt tension and it was way to low (~70 Hz). So I tightened up the belts and tuned them back to 85 Hz. Now I have a strange noise which sounds like it comes from a loose screw or a bearing. It is really hard to locate.</p>
<p>Anyone has an idea or run into the same problem?</p>
<p>Thanks</p>
<div id="wpfa-175138" class="wpforo-attached-file"><a class="wpforo-default-attachment" title="ee05f26f-bearing.mp4" href="//storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/wpforo/default_attachments/1742143522-ee05f26f-bearing.mp4" target="_blank" rel="noopener"> ee05f26f-bearing.mp4</a></div>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/noise-after-belt-tensioning-damaged-bearing/#post-740724</guid>
