Noise after belt tensioning (damaged bearing?)
[Resuelto] Noise after belt tensioning (damaged bearing?)
cryptomilk
(@cryptomilk)
As some prints where off today, I checked the belt tension and it was way to low (~70 Hz). So I tightened up the belts and tuned them back to 85 Hz. Now I have a strange noise which sounds like it comes from a loose screw or a bearing. It is really hard to locate.
Anyone has an idea or run into the same problem?
Thanks
Best Answer by cryptomilk:
It's the X axis motor 🙁
Respondido : 16/03/2025 4:45 pm
cryptomilk
(@cryptomilk)
RE: Noise after belt tensioning (damaged bearing?)
Respondido : 17/03/2025 11:13 am
Scott
(@scott-18)
I can't read your video, but if you're sure it comes from a motor, try to reach Prusa support to ask for a replacement. 🙂
Respondido : 17/03/2025 12:49 pm
cryptomilk
(@cryptomilk)
A replacement is already on the way from Prusa.
Respondido : 17/03/2025 1:10 pm
cryptomilk
(@cryptomilk)
I've replaced the X-axis motor today. Here is how you easily reinstall the pulley on the new motor: https://www.printables.com/model/1236389-core-one-x-axisy-axis-motor-pulley-assembly-tool
Respondido : 20/03/2025 3:25 pm
