Moving the print bed to its maximum height after printing
AvariCe
(@avarice)
Hello all,
I want the printer to move the bed to its maximum height.
If I understand correctly, I will have to change this command from the end code
{if layer_z < max_print_height}G1 Z{z_offset+min(max_layer_z+23, max_print_height)} F300 ; Move print head up{endif}
To this
G1 Z270 F100
Am I right? I haven't tested it since it could damage the printer if I get the command completely wrong.
Best Answer by chmax:
why not use the right variable then?
G1 Z{max_print_height} F300 ; Move bed down to bottom...
Respondido : 12/09/2025 12:25 pm
chmax
(@chmax)
RE: Moving the print bed to its maximum height after printing
Respondido : 12/09/2025 4:25 pm
1 les gusta
AvariCe
(@avarice)
Thanks!
Respondido : 12/09/2025 9:00 pm
Alienbliep
(@alienbliep)
I have try to find this too.
But when the core one starts a new print it lowers the bed agressivly a one or two cm's.
So when you print after an print it collapses Z on the bottom.
That's why i reversed back to stock g-code.
I also find that the core one forgets it's postion. Sometimes in the middle is 0mm. This is no problem because it check for 0mm before each print but maybe this has something to do with it?
a guy on reddit wrote this code: I really don't understand the second sentence.
; This will move the bed to 40mm above max z,
; or 40mm below the max height of the print, or max z
{if layer_z < max_print_height}G1 Z{z_offset+min(max(max_print_height-40, max_layer_z+40), max_print_height)} F720 ; Move print bed down{endif}
Respondido : 13/09/2025 2:45 pm
AvariCe
(@avarice)
Posted by: @alienbliep
I haven't noticed any collapsing yet using chmax's solution.
However, I did a couple of tests trying to cause the Z axis to collapse.
It didn't collapse after starting another print. Same for cutting the power off and then turning it on again.
In both cases though, it went the extra 5 mm that it can go.
The only scenario I couldn't test was tripping a red screen during printng, and I can't reproduce one.
Respondido : 13/09/2025 6:45 pm
Alienbliep
(@alienbliep)
I had it set to Z=274 or 275 mm i think. And that is flat on the bottom.
Anyway i tried this code mentioned here in the beginning:
M140 S0 ; turn off heatbed
M141 S0 ; disable chamber control
M107 ; turn off fan
G1 X242 Y211 F10200 ; park{if layer_z < max_print_height}G1 Z{z_offset+min(max_layer_z+50, max_print_height)} F720 ; Move bed down{endif}
M702 ; unload the current filament
M104 S0 ; turn off temperature
G4 ; wait
M572 S0 ; reset PA
M84 X Y E ; disable motors;
max_layer_z = [max_layer_z]
This would make the bed park at the bottom, then go back up to unload filament and then go back down half way.... and stop there.
I am now using this with an MMU: (excluded the mmu line in the middle: {if layer_z < max_print_height}G1 Z{z_offset+min(max_layer_z+50, max_print_height)} F720 ; Move bed down{endif}
But still at the very end after the unload filament job is done and the bed is already down it goes back up 1cm and then again down 1cm. Really strange when your already picking something from the bed....
{if layer_z < max_print_height}G1 Z{z_offset+min(max(max_print_height-20, max_layer_z+20), max_print_height)} F720 ; Move print bed down{endif}
M107 ; turn off fan
M104 S0 ; turn off temperatureG4 ; wait
M572 S0 ; reset PA
Stock mmu:
{if layer_z < max_print_height}G1 Z{z_offset+min(max_layer_z+1, max_print_height)} F720 ; Move print head up{endif}
M140 S0 ; turn off heatbedM141 S0 ; disable chamber control
M107 ; turn off fanG1 X242 Y211 F10200 ; park
G4 ; wait
M572 S0 ; reset PA
; max_layer_z = [max_layer_z]
Anyway i don't have any idea why the beginning line is so complicated. I don't understand what this means:
Respondido : 13/09/2025 7:12 pm
AvariCe
(@avarice)
Assuming I understand that correctly, the following happens with that line:
it checks whether the z layer is less than the max print height. Then it tells to move it vertically an amount that is calculated as follows:
z_offset (which is a constant var) + the smaller of the two: the maximum height of the print +1 or the max print height (which is 270).
After the calculation, it goes to the corresponding height at 270 mm/s
Esta publicación ha sido modificada el hace 9 months por AvariCe
Respondido : 13/09/2025 7:39 pm
