					                		MMU3 custom color change procedure ILO purge block - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/mmu3-custom-color-change-procedure-ilo-purge-block/</link>
                <lastBuildDate>Mon, 11 May 2026 15:12:37 +0000</lastBuildDate>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/mmu3-custom-color-change-procedure-ilo-purge-block/#post-760022</link>
                        <pubDate>Mon, 04 Aug 2025 18:23:45 +0000</pubDate>
                        <description><![CDATA[Here is the custom tool change code that I got from a chatbot.I am unable to test it soon, so dropping in case someone else has time and/or can see obvious problems prior to my testing.
; -...]]></description>
                        <content:encoded><![CDATA[<p>Here is the custom tool change code that I got from a chatbot.<br />I am unable to test it soon, so dropping in case someone else has time and/or can see obvious problems prior to my testing.</p>
<p>; --- BEGIN MMU3 TOOLCHANGE FIXED PURGE USING FILAMENT OVERRIDES ---<br />G92 E0 ; Reset extruder<br />G1 Z{max(layer_z + 2.0, 3)} F720 ; Lift nozzle to avoid part collision<br />G1 X86 Y-14 F9000 ; Move to fixed purge position<br />G1 Z1.2 F720 ; Lower to purge height</p>
<p>; --- Ram &amp; Unload using filament-specific values ---<br />G1 E-0.8 F1000 ; Soft initial retract<br />G1 E{-18 + filament_unload_extra_length} F1000 ; Ram with added yank<br />G1 E-{filament_unload_length} F{filament_unload_speed} ; Full unload<br />G4 P300 ; Dwell to settle</p>
<p>; --- MMU Tool Change ---<br />T ; Switch to next filament<br />G92 E0 ; Reset E after new filament load</p>
<p>; --- Load and Purge with filament-specific length ---<br />M109 R{temperature} ; Wait for stable temp<br />G1 E{filament_load_length} F300 ; Load and purge<br />G92 E0 ; Reset E again</p>
<p>; --- Optional Silicone Wiper Mod ---<br />G0 X76 Y-18 Z1.2 F10000; <br />G0 X40 Y-14 Z1.2 F10000; <br />G0 X76 Y-18 Z1.2 F10000; <br />G0 X40 Y-14 Z1.2 F10000; <br />G0 X76 Y-18 Z1.2 F10000; <br />G0 X40 Y-14 Z1.2 F10000; <br />G0 X76 Y-18 Z1.2 F10000; <br />G0 X40 Y-14 Z1.2 F10000;<br />G0 X76 Y-18 Z1.2 F10000;</p>
<p>; --- Lift for return ---<br />G1 Z{layer_z + 0.6} F720</p>
<p>; --- END MMU3 TOOLCHANGE FIXED PURGE ---</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>etmidust</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/mmu3-custom-color-change-procedure-ilo-purge-block/#post-760022</guid>
                        <title>MMU3 custom color change procedure ILO purge block</title>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/mmu3-custom-color-change-procedure-ilo-purge-block/#post-759987</link>
                        <pubDate>Mon, 04 Aug 2025 14:39:05 +0000</pubDate>
                        <description><![CDATA[Background:Core one with community MMU3 mod, and silicone wiper mod (with waste bin)Question/Idea:Is there a way to use the custom tool change gcode in the printer settings to park the extru...]]></description>
                        <content:encoded><![CDATA[<p>Background:</p><p>Core one with community MMU3 mod, and silicone wiper mod (with waste bin)</p><p>Question/Idea:</p><p>Is there a way to use the custom tool change gcode in the printer settings to park the extruder slightly off the front of the print bed and just dump what would be the purge blocks' worth of filament into the printed waste bin then wipe the nozzle on the silicone sock before resuming the print? I don't understand the gcode abilities enough to know if this is possible as an option or if it may need a custom post export script maybe?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/mmu3-custom-color-change-procedure-ilo-purge-block/#post-759987</guid>
