MMU Nextruder mod tension screws
Page 2 / 2
Thorsten Lachmann
(@thorsten-lachmann)
RE: MMU Nextruder mod tension screws
Happens that while loading?
Posted by: @alienbliep
No regular pla.
Just happened again.
On returning the extruder:
My Printables models including Nextruder improvements: https://www.printables.com/@ThorstenLach_1801966
Publié : 26/11/2025 8:07 pm
Alienbliep
(@alienbliep)
Nu during unload.
The unload time seems to long for me.
It unloads longer then necessart
Publié : 26/11/2025 8:23 pm
Thorsten Lachmann
Was it unloaded manually by UI or while printing?
Which GCode was used for that? was the unload initiated by Tn command or was M702 to unload? because the behavior when unloading with Tn command is not good. With Tn command the filament sensor is deactivated while unload. The MMU tries forcly to unload but the extruder doesn´t move after the first try failed. I that case such grinding could happen if the extruder wheel blocks the filament from unload...
Greets Thorsten
Publié : 27/11/2025 1:22 am
Page 2 / 2
