Layer Shift CoreONE Single Material FW 6.3.5-alpha+10514
SirMakesALot
(@sirmakesalot)
Firmware: 6.3.5-alpha+10514. Layer shift I am having layer shift. It is happening over and over again. I have had the printer running just fine for the past few weeks and all of a sudden im getting layer shift. Not at the same layer either. I have tightened the belts and ran a test print and that came out just fine. Then I change the filament to my specialty filament and run and sure enough i get a layer shift.
Is there any way for me to find out which was the last layer printed and start remove the shift and restart from a specific layer ?
How do you turn on crash detection? It doesnt seem to be showing or i cant find it.
Single material, .4 nozzle .25 layer height. PLA Silk and dont see any warping. NEED HELP fixing please
Napsal : 04/10/2025 6:47 pm
RE: Layer Shift CoreONE Single Material FW 6.3.5-alpha+10514
Is the layer shift always happening in the same direction as in the photo? Wondering if the umbilical cable is sagging and getting between the print head and the X motor housing?
Napsal : 05/10/2025 2:02 pm
SirMakesALot
(@sirmakesalot)
didn't even think of that i will definitely keep an eye out for that. I also saw that I was running 215C on the silk PLA. And on my MK4S I am running it at 225C with no problem. I cleaned the nozzle with a needle and upped the temp and so far so good. But then again the tall print I moved to the MK4 and on the Core maybe one inch in height. So I will keep an eye on it and see. Thank you for the input.
take a look at those pictures, do you think its riding to low ? i think it looks fine but i dont have anything to reference to.
This post was modified před 4 hours by SirMakesALot
Napsal : 05/10/2025 5:10 pm
