Getting a warning "A filament specified in the G-code is either not loaded or wrong type"
Hi all,
I got recently my Core One and I had a few prints with regular PLA. All ok so far.
I then wanted to print LW-PLA from Colorfabb and I did all the settings to the latest prusa slicer version. When I try to print that part, I get the warning "A filament specified in the G-code is either not loaded or wrong type" and then if I select to continue the print, after some layers there is a massive shift.
I have set my Prusa slicer correctly (or at least I believe I did so) - please see attached pics.
I also checked the section Filament --> Custom G-code and I see something which is not matching, referring to.*PRINTER_MODEL_MINI.*
Anyone that could help?
RE: Getting a warning "A filament specified in the G-code is either not loaded or wrong type"
Create a separate LW-PLA profile, copy from the regular PLA and then adjust: Flow: 50–60%, speed: low (~30mm/s or less). temperature: ~230–240°C (depending on the machine).
