Filtration and Chamber Fan Operation
MarkusA380
(@markusa380)
Mitglied
Hello,
I received my Core One yesterday, and so far everything is working great.
However, I am a bit confused regarding the chamber filtration.
I have installed the Advanced Filtration System, and configured it in the printer settings.
When I enable "Filter All Materials", the blower fan turns on. But the chamber fans don't seem to do so, although I can enable them separately in the settings.
I don't quite understand the logic, after all both fan systems are on the same airway, once infront of the filter, and once behind.
What am I missing?
Why does the printer not use the fans to cool the chamber for PLA instead of the opening at the top?
Especially as I want to filter PLA as well, as I share a living room in a cold countrywith this machine.
Veröffentlicht : 04/12/2025 3:16 pm
RE: Filtration and Chamber Fan Operation
Once you install the advanced filtration kit, then the chamber fans are no longer needed. The filtration system has it's own blower which pulls air from the chamber. The fans are still there to hold on to the chamber thermistor that you see in the center.
Veröffentlicht : 04/12/2025 3:22 pm
