File Upload Failed
Lord Zardoz
(@lord-zardoz)
File Upload Failed
Had the Core One for a couple of months and today I get a 'file upload failed' message in Easyprint.
I can still print the Benchy from the memory stick.
Posted : 23/07/2025 5:39 pm
Try a different memory stick. The ones supplied by Prusa seem to go bad (mine did). Make sure it's relatively small (like 16GB is plenty), USB2 and that it's formatted with FAT32
Posted : 24/07/2025 10:35 pm
Raaz
 Raaz
(@raaz-2)
RE: File Upload Failed
I can recommend the SanDisk Max Endurance SD card with the little SanDisk USB adapter (make sure it's the max endurance, not high endurance).
It's one of the few cards that work fine in dashcams. I had 2 fails with the Prusa stick in the first week of usage and none since then. And the adapter doesn't stick out as far, so the risk of accidently hitting it is reduced.
Posted : 25/07/2025 10:29 pm
