"Filament loading timed out." error during filament loading.
mk_root
(@mk_root)
Miembro
I trying to load filament.
When I`m going to menu Filament -> Load filament -> PLA (for example, same situation with PETG) printer showing "Parking" message, than "Filament loading timed out." error.
IMG_6650
I tried reset/reboot/power drain but it did not help.
I tested all available firmwares:
COREONE_firmware_6.3.0.bbf
COREONE_firmware_6.3.1.bbf
COREONE_firmware_6.3.2.bbf <- Current
but it change nothing.
Does someone have some idea how to load filament to print?
Respondido : 11/05/2025 2:00 am
ByteChild
(@bytechild)
Miembro
RE: "Filament loading timed out." error during filament loading.
I had the same problem. Recalibrating the filament sensors did the trick for me.
Respondido : 13/05/2025 9:02 am
3 les gusta
mk_root
(@mk_root)
Miembro
Thank you. Working! Recalibration of the filament sensors helped.
Respondido : 18/05/2025 3:43 am
Chip the printer
(@chip-the-printer)
Miembro
RE: "Filament loading timed out." error during filament loading. Jammed!
I tried loading Prusament PETG today and it just would not load. First is said to clean the filament sensor and try again. Then it started making noises that indicated to me that it was jammed somewhere between the gears that grab the filament and the nozzle. It tries to load it and cannot. I tried reading on how to fix it but I have not found the correct location. I must be tired or something as I cannot create a new topic for this problem and I cant find anywhere to ask for help! I've had this (factory assembled) core one for several weeks and this is the first issue. Dont mean to hijack your post here! but i need help!
Respondido : 22/05/2025 12:58 am
bobx26
(@bobx26)
Miembro
Thanks for this - I also had the timeout after changing nozzles, so really pleased that the fix (of doing the recalibration) worked so well and easily!
Respondido : 31/05/2025 8:30 am
