					                		Door handle separation after High Temperature Print - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/door-handle-separation-after-high-temperature-print/</link>
                <lastBuildDate>Mon, 11 May 2026 15:34:55 +0000</lastBuildDate>
                        <title>RE: Door handle separation after High Temperature Print</title>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/door-handle-separation-after-high-temperature-print/#post-783984</link>
                        <pubDate>Sun, 01 Mar 2026 04:20:18 +0000</pubDate>
                        <description><![CDATA[I&#039;ve experienced this too.  Prusa needs to find a different HVAC adhesive rated for higher temperatures, or in future models, replace the adhesive with fasteners as you have. Mark]]></description>
                        <content:encoded><![CDATA[<p>I've experienced this too.  Prusa needs to find a different HVAC adhesive rated for higher temperatures, or in future models, replace the adhesive with fasteners as you have. </p><p>Mark</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>mbiasotti</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/door-handle-separation-after-high-temperature-print/#post-783984</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/door-handle-separation-after-high-temperature-print/#post-775275</link>
                        <pubDate>Mon, 22 Dec 2025 20:19:10 +0000</pubDate>
                        <description><![CDATA[Posted by: @uncivilservant I had no issues during my initial test prints with PLA, but after an ABS print where the chamber was heated for seven hours, the adhesive holding the door handle o...]]></description>
                        <content:encoded><![CDATA[<blockquote data-userid="603259" data-postid="775216" data-mention="uncivilservant"><div class="wpforo-post-quote-author"><strong>Posted by: @uncivilservant </strong></div><p>I had no issues during my initial test prints with PLA, but after an ABS print where the chamber was heated for seven hours, the adhesive holding the door handle on has degraded, and instead of opening the door, it tries to lever itself off if not held just so.  It has not improved after cool-down, and I'm likely to need to replace the adhesive.  What's an appropriate bonding material that will survive high temperature prints?</p></blockquote><p>I would leave the adhesive in place (it is messy...) and just add two M3 screws and nuts. There should be pre-drilled matching holes in the handle and door pane, and there are larger holes in the right-hand frame profile to receive the screw heads.</p><p>(However, the lower hole is missing from the left frame profile, at least in the early Core Ones. So in case you swapped the hinges to the other side, the screw head might touch the frame, leaving the door seal slightly ajar.)) </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/door-handle-separation-after-high-temperature-print/#post-775275</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/door-handle-separation-after-high-temperature-print/#post-775272</link>
                        <pubDate>Mon, 22 Dec 2025 19:57:46 +0000</pubDate>
                        <description><![CDATA[3M VHB double sided tape should be ok.I used this to redo the handle given I had trouble installing it with the supplied tape initially.I&#039;ve only done PLA and PETG prints but it is holding u...]]></description>
                        <content:encoded><![CDATA[<p>3M VHB double sided tape should be ok.</p><p>I used this to redo the handle given I had trouble installing it with the supplied tape initially.</p><p>I've only done PLA and PETG prints but it is holding up well. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>stevo1957</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/door-handle-separation-after-high-temperature-print/#post-775272</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/door-handle-separation-after-high-temperature-print/#post-775243</link>
                        <pubDate>Mon, 22 Dec 2025 15:25:57 +0000</pubDate>
                        <description><![CDATA[I suppose screws count as a bonding material.]]></description>
                        <content:encoded><![CDATA[<p>I suppose screws count as a bonding material.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>UnCivilServant</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/door-handle-separation-after-high-temperature-print/#post-775243</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/door-handle-separation-after-high-temperature-print/#post-775237</link>
                        <pubDate>Mon, 22 Dec 2025 14:51:54 +0000</pubDate>
                        <description><![CDATA[Had the same happen. Decided to forego any adhesives and go with a more robust solution:]]></description>
                        <content:encoded><![CDATA[<p>Had the same happen. Decided to forego any adhesives and go with a more robust solution: https://www.printables.com/model/1411788-prusa-core-one-door-handle-wedge</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>FoxRun3D</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/door-handle-separation-after-high-temperature-print/#post-775237</guid>
                        <title>Door handle separation after High Temperature Print</title>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/door-handle-separation-after-high-temperature-print/#post-775216</link>
                        <pubDate>Mon, 22 Dec 2025 12:09:14 +0000</pubDate>
                        <description><![CDATA[I had no issues during my initial test prints with PLA, but after an ABS print where the chamber was heated for seven hours, the adhesive holding the door handle on has degraded, and instead...]]></description>
                        <content:encoded><![CDATA[<p>I had no issues during my initial test prints with PLA, but after an ABS print where the chamber was heated for seven hours, the adhesive holding the door handle on has degraded, and instead of opening the door, it tries to lever itself off if not held just so.  It has not improved after cool-down, and I'm likely to need to replace the adhesive.  What's an appropriate bonding material that will survive high temperature prints?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/door-handle-separation-after-high-temperature-print/#post-775216</guid>
