Door handle separation after High Temperature Print
UnCivilServant
(@uncivilservant)
I had no issues during my initial test prints with PLA, but after an ABS print where the chamber was heated for seven hours, the adhesive holding the door handle on has degraded, and instead of opening the door, it tries to lever itself off if not held just so.  It has not improved after cool-down, and I'm likely to need to replace the adhesive.  What's an appropriate bonding material that will survive high temperature prints?
Posted : 22/12/2025 12:09 pm
RE: Door handle separation after High Temperature Print
Had the same happen. Decided to forego any adhesives and go with a more robust solution: https://www.printables.com/model/1411788-prusa-core-one-door-handle-wedge
Posted : 22/12/2025 2:51 pm
UnCivilServant
(@uncivilservant)
I suppose screws count as a bonding material.
Posted : 22/12/2025 3:25 pm
stevo1957
(@stevo1957)
3M VHB double sided tape should be ok.
I used this to redo the handle given I had trouble installing it with the supplied tape initially.
I've only done PLA and PETG prints but it is holding up well.
Posted : 22/12/2025 7:57 pm
Posted by: @uncivilservant
I would leave the adhesive in place (it is messy...) and just add two M3 screws and nuts. There should be pre-drilled matching holes in the handle and door pane, and there are larger holes in the right-hand frame profile to receive the screw heads.
(However, the lower hole is missing from the left frame profile, at least in the early Core Ones. So in case you swapped the hinges to the other side, the screw head might touch the frame, leaving the door seal slightly ajar.))
Posted : 22/12/2025 8:19 pm
mbiasotti
(@mbiasotti)
I've experienced this too.  Prusa needs to find a different HVAC adhesive rated for higher temperatures, or in future models, replace the adhesive with fasteners as you have.
Mark
Posted : 01/03/2026 4:20 am
