Different Z lead screw travel between MK4S upgrade screws and Core One kit — 2 mm mismatch
Seite 4 / 6
Albert Lozano
(@albert-lozano)
Instructions:
Calibrate Z.
Use the display to raise Z to around 50-60 mm and take your measurements.
(See image)
Diese r Beitrag wurde geändert Vor 2 months von Albert Lozano
Veröffentlicht : 25/02/2026 11:21 pm
RE: Different Z lead screw travel between MK4S upgrade screws and Core One kit — 2 mm mismatch
Posted by: @albert-lozano
Instructions:
Calibrate Z.
The comment in the image, "gap will increase as you go higher", is important. There may also be a fixed left vs. right difference due to tolerances in the frame and chassis. To separate it from the effect of unmatched thread pitch, I would do this measurement twice, at two different heights of the bed, say 10 mm and 110 mm below the nozzle. Then the change in the left vs. right discrepancy over 100 mm travel can be determined.
Veröffentlicht : 26/02/2026 6:36 am
gb160
(@gb160)
That approach is good for the front 2, but not any good for the rear leadscrew.
Veröffentlicht : 26/02/2026 4:35 pm
Lynn
 Lynn
(@lynn)
There is another common  and related complaint that seems to fit this thread. That is loud and scarry rubbing and vibrational sounds the core one produces when tranvsersing the full range of the Z-axis.
In my case, I was attempting to groom my mk4s to coreone+  upgrade to eleminate those noises when I noticed the front lead screws were tiled backwards with the bed at the bottom and tilted frontwards when at the top. I didn't attempt to measure the lead screw pitchs, but it was visually obvious that the bed tilt changed over the full range of Z travel. My bed is tilting along the y axis, not the x.
To me the most likely explainatations that fit both of these observations is that the lead screws are  rotating at differnet speeds, one or more of them are slipping poles, or the lead screw pitchs are not the same. In any case this definely a design or manufacturing flaw that prusa needs to address.
Veröffentlicht : 26/02/2026 11:04 pm
Albert Lozano
(@albert-lozano)
Posted by: @gb160
In that case the best is a digital clinometer
Veröffentlicht : 26/02/2026 11:44 pm
Posted by: @lynn
[...] I noticed the front lead screws were tiled backwards with the bed at the bottom and tilted frontwards when at the top. I didn't attempt to measure the lead screw pitchs, but it was visually obvious that the bed tilt changed over the full range of Z travel. My bed is tilting along the y axis, not the x.
I think you are misinterpreting this. The tilting lead screws are due to lateral forces which the black trapezoidal nuts exert on the screws. This is a common alignment issue in the Core One, because the assembly instructions do not ensure that the lateral position of the nuts agrees with the position defined by the smooth vertical rods that guide the heatbed. But it is easily fixed:
  • Drive the heatbed all the way down.
  • Loosen the six M3 screws which attach the three trapezoidal nuts to the heatbed (two per nut). This lets the nuts find lateral positions that are in agreement with the smooth rods.
  • Probably the lead screws will already have straightened and centered when you loosened the M3 screws. If they are still a bit slanted, center each top end with your fingers while you fasten the corresponding M3 screws again. Do not overtighten the M3 screws; the nuts are plastic (POM).
This should give you smooth Z movement without lateral strain and push on the lead screws. If the Z drive still "groans" during longer moves, it needs to be lubricated. Apply a bit of the lubricant that came with the kit to the lead screws.
Veröffentlicht : 27/02/2026 5:24 am
gb160
(@gb160)
Posted by: @gb160
Agreed 100% 👍
What was the outcome with yours? Did you contact Prusa?
Veröffentlicht : 27/02/2026 8:16 am
gb160
(@gb160)
Although this is the best approach, I hate the fact that soon after lubrication the screws are then a magnet for dust and other airborne contaminates.
Veröffentlicht : 27/02/2026 8:20 am
mnentwig
(@mnentwig)
Frankly, I don't see why anybody would want to use an inclinometer. It needs to be absurdly precise to show small errors, e.g. better than o.o5 degrees for 200 µm offset over the spindle spacing (that is, pi/180*atan2(0.02, 300)). Having two digits after the decimal point is still a long way from being accurate ... The only advantage I can think of, it doesn't distract the user with needless worry about "small" errors that may be "totally negligible - really", still clash inconveniently with marketing language. Do your own math 🙂
To confirm the relative alignment between the three screws,
- home and move the print bed up to Z=0
- move the print head near each of the spindles and turn it manually (against the resistance of the Z motors) until the print bed is perfectly parallel, relative to the head plane. A playing- or business card serves as ad-hoc feeler gauge between print bed and nozzle to set consistent distance at all three spindles, within +/- 0.5 motor step if working accurately.
- run the print bed down near (but not touching) the bottom and use a suitable object e.g. a capped bottle to confirm that the distance is still consistent near all three spindles.
Veröffentlicht : 27/02/2026 9:41 am
gb160
(@gb160)
Posted by: @mnentwig
Using the nozzle just throws in another variable (whether the gantry is sitting perfectly flat) so I don't think that's a good method at all.
Using an inclinometer in this application is over the entire length of the screws, where Z is calibrated, and somewhere close to the top...showing around 0.3 degree tilt where a within tolerance leadscrew is compared to an out of tolerance leadscrew.
It's a quick test that shows repeatable results.
Veröffentlicht : 27/02/2026 9:56 am
Lynn
 Lynn
(@lynn)
Posted by: @  Jürgen
You might be correct about the bending forces caused by the trapezoidal nuts, I thought of this as well and in fact spent nearly 2 hours trying to get the T-nuts, the build plate's front mounting brackets, and the motor mounts to settle into a non-binding position.  I even lubricated the rods with dry PFTE lubricant. I finally gave up because I couldn't change the noise generation, nor have I been able to keep the bed parallel with the carriage.
On my printer after several prints I will start to get a visually obvious tilt to the print bed. Doing the z-calibration routine will drive the bed against the T- nut screws, but usually I have to rotate the back lead screw an additional turn or two so to bottom out the back of the plate.  After this intervention, the print bed appears parallel. But the noises remain. In my case, all the vibration is being transmitted up the right front lead screw. I have been able to very effectively dampen the noise by folding a piece of felt around the top of the screw to absorb the vibration, but I haven't made this permanent yet.
But keeping the bed parallel is by biggest concern.
Veröffentlicht : 27/02/2026 12:50 pm
mnentwig
(@mnentwig)
Posted by: @gb160
Err... I would argue exactly the other way. Print height (/distortion) is bed-to-nozzle distance so measure it directly.
It's as simple as it gets, arguably with the smallest number of contributing error terms.
Veröffentlicht : 27/02/2026 1:03 pm
gb160
(@gb160)
Posted by: @gb160
An inclinometer is as simple as it gets.
Calibrate Z.
Zero Inclinometer
Raise Bed
Check inclinometer.
You're overthinking it mate.
Veröffentlicht : 27/02/2026 1:11 pm
mnentwig
(@mnentwig)
I respectfully disagree:
My hardware-store (0.05 degree display resolution) instrument horizontally on the print bed gives the following readings,  when I turn one of the spindles:
StepCount / angle reading
0 / 0
1 / 0.05
2 / 0.1
3/ 0.1
4 / 0.1
5 / 0.15
6 / 0.2
7 / 0.2
8 / 0.2
9 / 0.25
10 / 0.25
So it's a fairly crude measurement: One step is about 140 µm, which doesn't seem insignificant for an error that shouldn't be there in the first place (baseline print bed calibration is much more accurate than this, otherwise the first layer would never stick). But maybe I'm overthinking this 🙂
Veröffentlicht : 27/02/2026 1:50 pm
gb160
(@gb160)
Finally we can agree on something ! 😂
Veröffentlicht : 27/02/2026 2:12 pm
Etadriver
(@etadriver)
Yes, you're both right. The inclinometer method only shows, initially, whether a faulty Z-axis spindle is installed. @mnentwig's more precise method then provides the exact deviation as a measurement. But it can't be that Prusa passes on the cost of their SQM learning curve to customers by shipping these defective parts. Of course, faulty shipments can always happen, but a proper incoming goods inspection should filter such things out, and Prusa should take appropriate action. Not the customer! Believe me, I know what it's like to transition from a startup, which takes a more relaxed approach, to a mass-production manufacturer.
Veröffentlicht : 27/02/2026 3:41 pm
Posted by: @lynn
So, did you try to get the T-nuts and the smooth rods/linear bearings into a consistent position in the way I suggested? I have yet to hear about a printer where that did not do the trick.
If you observe a bed tilt which gradually accumulates over time, as you drive the bed up and down, that is an indication of step loss -- caused indeed by a binding Z drive.
Besides a strained lateral positions of the the T-nuts, binding of the Z drive can also be caused by T-nuts with a malformed thread. We have had several reports of that in the recent months. When you drive the bed all the way down and completely remove the M3 screws which hold the T-nuts, you can rotate the nuts up the lead screws by hand. Please check whether all of them move freely. If one or more nuts are hard to turn, you will need (free) replacements from Prusa support.
Veröffentlicht : 27/02/2026 4:00 pm
gb160
(@gb160)
I used this method and it's a LOT better than previously. I cleaned all the lubricant off and the only time it 'groans' is when moving the Z at fast speeds. F720, F800, F1000 are all groan free. It groans a bit at F2000, but in the real world the Z motors never travel that fast anyway so its all good 👍
And this is with a rear leadscrew with sketchy pitch.
Veröffentlicht : 27/02/2026 5:15 pm
Yasar
(@yasar)
I did it by homing and moving the X-carriage (from menu) (nozzle on the left and back center) and rotating the spindle so that the nozzle touches, and then everything is level... there's nothing you can do, one driver is causing problems, we need 3 drivers, then move all 3 spindles and hom... then you'll have everything level.
Veröffentlicht : 28/02/2026 4:40 pm
gb160
(@gb160)
Posted by: @yasar
One driver isn't the problem. Lead screws with different pitches are the problem.
Levelling the bed at the top isn't going to correct dimensional inaccuracy caused by this problem when you're printing large parts.
It could be corrected by software if there were individual drivers, the (much simpler) alternative is better QA on the lead screws in the first place.
Veröffentlicht : 28/02/2026 4:55 pm
Seite 4 / 6
