Different Z lead screw travel between MK4S upgrade screws and Core One kit — 2 mm mismatch
My Core One comes from a MK4S upgrade kit, and I’ve found a mechanical mismatch in the Z axis.
The two lead screws reused from the MK4S rotate exactly the same number of turns as the new lead screw included in the Core One kit, but their trapezoidal nuts move about 2 mm less over the full travel.
To compensate, I had to add a 2 mm spacer at the lower left Z calibration stop so the bed is level near the top of the travel.However, as the bed moves down, the tilt appears progressively, reaching about 2 mm out of level near Z = 0 on the MK4S screw side.
Small prints are fine, but tall prints show increasing layer issues as Z increases.This suggests a different effective pitch or cumulative tolerance between screws.
I’m attaching two photos of a bubble level showing the bed level at the start and at the end of the travel.
Has anyone else seen differences in lead screw pitch or effective travel between MK4S and Core One screws?
RE: Different Z lead screw travel between MK4S upgrade screws and Core One kit — 2 mm mismatch
Oh yes... Here's the original thread about this. The link goes to the post where @pavel-brych has identified the root cause.
Prusa support will send you a replacement lead screw or two, but it takes some back & forth to convince them. Your pictures of the spirit level will be helpful; that's a demonstration they have asked me to provide (in a video, showing the change while the bed is travelling upwards).
Are the lead screws replaceable? I always thought they’re fixed to the Z motors ?
They are fixed. When Prusa agrees to provide remplacements, you get the complete replacement units: lead screw, motor and cable. It's a bit of a hassle to swap them on a fully built printer -- front and side skirts around the base plate need to come off so you can pull the motors out towards the bottom.
Jesus Ive just read the beginning of that thread and think I might have that issue ! I was batch one also.
Sorry to be a pain mate but is there a tldr to find out if Im affected? I have decent callipers but thats about it regarding measuring tools.
Calipers are very suitable in terms of accuracy, but tricky to use here because it is so easy to miscount the threads. And depending on the size of the calipers it may be difficult to fit them in. A nice measuring method has been proposed later in that thread:
Move the bed all the way up, cut strips of paper a tad shorter than the free length of the lead screws and ~ 5 cm wide. Fold a paper around each lead screw and secure it in place, e.g with paper clips from behind. Then copy the thread pattern onto the paper by rubbing with the side of a pencil -- like we used to copy coins as kids.
This will give a distortion-free picture of each lead screw's thread. (More accurate that photos.) You can either measure them manually, after counting off groups of 10 turns of the thread. Or the fancy version, put all strips next to each other on a flatbed scanner, scan them and measure the picture in your favorite imaging software.
Cheers, I'll try the quick method with the spirit level first. If I video that will it be enough to convince support?
If I am affected, is it just 1, or 2 motors/leadscrews that will need replacing ?
The spirit level test is not very sensitive, but it gives you a first idea. You will need to check sideways and front-to-back changes to figure out which screw is off. Personally I prefer the direct measurement of the screw pitches.
You will typically have two identical screws and one with a different pitch. Problem is that Prusa only has one part number; they can't send you screws with a specific pitch.
They sent me one replacement at first, and of course it turned out to have the exact pitch of the odd one out I already had -- so I now had two of each pitch. I contacted support again, asking for one more, which I expected to match either one pair or the other. But that time round, they insisted on sending me three new screws, all taken from the same shelf.
I noticed someone in that thread uploaded a tool which should be a pretty simple, very quick check to see if I'm affected.
Honestly I'm amazed that this hasn't been picked up on more. Could be a hell of a lot of affected machines out there....quite staggering that there are still new printers being shipped with the problem.
I guess people won't notice it unless they're printing tall parts where dimensional accuracy is critical, the vast majority of the parts I print are quite small/flat, but with my warranty window drawing to an end its best I get on this straight away.
Cheers for the pointers !
Mine is definitely affected also.
My initial spirit level test is showing almost identical tilt to your images.
@jurgen-7 Do you remember when we got the kits, 2 of the z motors were together, and 1 motor was in its own packaging....was it the one on its own that was out of tolerance for you ?
Also a quick FYI, there's an app called Phyphox, which lets you access all the raw data from your phones sensors. So long story short, you can measure the bed tilt difference between Z:270 and Z:0, and on this occasion it's 0.3 degrees.
I would've thought it would be more than that as it's clearly visible with a spirit level.
I can't say for sure which lead screw was the odd one out. The pre-packed box contained one motor with a short and one with a long cable; the one packed separately had an identical label and also a long cable (if I recall correctly). The motor with the "odd" lead screw pitch was one of the two long-cabled ones. So it may very well have been the one that was packed separately, and I assume that was the case -- but can't say for sure.
The resolution of a spirit level is not that bad -- actually better than my phone's "virtual spirit level". The better spirit levels resolve 0.5 mm per meter, the more basic ones 1 mm per meter. That translates to 0.03° or 0.06° resolution, respectively. Although those specs seem to be on the optimistic side: On my "0.5 mm/m" level, I could clearly see a 0.3° change, but don't think I could have made out anything 10x smaller.
Yeah I went a bought a £10 Magnusson this morning, and thats 0.5mm/m
I've been onto support, and the guy was able to confirm what the spirit level showed, through pictures and a video.
I'm waiting for him to get confirmation regarding sending a replacement out...I really cant see how they can dispute it or offer another solution, the spirit level 'evidence' is pretty conclusive.
My main fear is that they'll send out one with the same pitch as my 'odd one out'. I'll cross that bridge if I have to.
So my understanding is that the leadscrew that is out of tolerance (front right in my case) is making the bed travel slightly further than it should compared to the other 2 motors, which in turn causes the tilt?
In my case, I seem to recall that two of the screws were slightly "faster" than the nominal pitch -- 201 mm per 100 turns -- while the odd one was a bit slower. So the bed travelled slightly less in the odd corner, resulting in a compressed print there.
Hi everyone,
Following the discussion about the skewed XY plane, I have performed measurements with a digital inclinometer to quantify the error.
The results are consistent with a lead screw pitch mismatch: I measured a 0.35° slope difference between the top (Z-max) and the bottom (Z=0) of the travel.
For those wondering how this translates to linear distance, here is the math based on the Prusa Core One's bed width (approx. 320 mm between support points):
Error=tan(0.35∘)×320 mm≈1.95 mm
This 1.95 mm discrepancy over the 275 mm travel confirms a ~0.7% lead error. This is not a mechanical assembly issue or a software calibration problem; it is a physical hardware defect where the lead screws have different effective pitches.
I have already contacted Prusa Support with this data. Given that this seems to be a batch issue with the MK4S to Core One upgrade kits, I strongly recommend everyone experiencing "Z-groaning" or layer shifts in tall prints to perform this check.
Hi everyone,
For those wondering how this translates to linear distance, here is the math based on the Prusa Core One's bed width (approx. 320 mm between support points):Error=tan(0.35∘)×320 mm≈1.95 mm
Thats basically identical to the problem on my Core One mate, although mine wasn't a Mk4 to Core One kit, mine was just a complete Core One kit. Out of interest what did Prusa suggest? Are they sending you a new motor?
I don't expect it to cause groaning movement or layer shifts, but dimensional errors of large prints. Unfortunately the problem is not limited to conversion kits, but has also been seen in full kirs and even factory-built printers.
Hi jürgen,
I respectfully disagree that this only affects dimensional accuracy. In a system where the bed moves away from the nozzle, a pitch discrepancy creates a dynamic skew.
The Mesh Bed Leveling (MBL) is performed at the top, but that map becomes invalid as the bed descends and the plane tilts. This leads to inconsistent nozzle-to-layer distance, affecting extrusion quality and layer bonding in tall prints.
Furthermore, this geometry conflict creates significant lateral tension between the rigid linear rails and the tilting bed, which is a primary cause of Z-axis groaning and premature wear on the POM nuts and bearings. It’s not just about the final part being 2mm off; it’s about the mechanical integrity of the printer during the entire process.
Hi jürgen,
I respectfully disagree that this only affects dimensional accuracy. In a system where the bed moves away from the nozzle, a pitch discrepancy creates a dynamic skew.The Mesh Bed Leveling (MBL) is performed at the top, but that map becomes invalid as the bed descends and the plane tilts. This leads to inconsistent nozzle-to-layer distance, affecting extrusion quality and layer bonding in tall prints.
Hi mate, what was Prusas response to your findings? Are they sending you a new motor/motors?
