DC Solar power supply
JSS
 JSS
(@jss)
A warm hello,
is there anything to keep in mind, when i want to run the CoreOne on LiFePo Battery 710Ah (Solar charged) it is a DC 24V 1.6kW Peak Solar System form a Expedition Truck wich is parked in front of our house. I bought a Step down Converter to bring down the 28V DC Batterie voltage to the 24V DC Printer. The thing holds 600W wich should be enough.
Thanks to share you thoughts. ( Im living in Mexico where the sun is seen quite often )
Stefan
Questa discussione è stata modificata 8 months fa 2 tempo da JSS
Postato : 22/10/2025 6:27 pm
Just bear in mind that some larger prints take days so you need enough battery capacity to run through the dark hours and days when there is storm overcast or falling leaves or dust obscure the solar panels.
Postato : 23/10/2025 12:33 am
JSS
 JSS
(@jss)
RE: DC Solar power supply
@diem .... im not in doubt that allmost 20Kwh are no enough in that case... beside i could switch back to grid all the time... thx
Postato : 23/10/2025 4:19 pm
