Custome GCode inserts for temprature changes not working.
SullySquatch
(@sullysquatch)
I am trying to print a temperature tower for PETG.  Everything looks fine when setting the temp changes on the custom GCODE insert in Prusa Slicer, but the printer never changes the temp. I have started from scratch 4 times and am getting very frustrated. Using M109 S250 etc. Which waits on the temp to change then prints
Posted : 20/12/2025 5:06 pm
RE: Custome GCode inserts for temprature changes not working.
My suggestion is to download OrcaSlicer. In the Calibration menu you can select and print a temperature tower (amongst many other calibration tests). I use OrcaSlicer exclusively to run these tests then use the results to update the PrusaSlicer profiles.
Posted : 20/12/2025 7:48 pm
If you upload the 3mf project file here, we can take a look. Zip compress it before upload or the forum software will choke. Use Attach file. For the love of god, don't post gcode, which nobody wants to sift through 🙂
Posted : 20/12/2025 8:57 pm
SullySquatch
(@sullysquatch)
Great Thank You.
Posted : 20/12/2025 9:02 pm
