Crash Detected
Page 2 / 2
RangerRoy
(@rangerroy)
RE: Crash Detected
Posted by: @m-zielinski
The reading from the strain gauge sensor is fluctuating. It doesn't matter if it's hot or cold. I'm waiting for a new one to arrive.
@Wojta, do you know which wire was bent or damaged too much?
How much fluctuation? I think a certain amount is "normal" but large spikes are a sign you might have issues. On my fully functional zero issues MK4S at any static reading there is about +-20 which seems to be acceptable. I think anything close to that should be fine.
Posted : 13/07/2025 6:06 pm
Woyta
(@woyta)
RE: Crash Detected
Printer was assembled, new out of box. No visual damage on cable. Fluctuation was in thousands. Normaly +/-70 then it jumped to -4000(+) I thing that lowest number I saw was -6500.
I tried to pull wires but all seems to be secured. I dont know pinout of this cable so I didnt check for continuity/resistance. But I still have that cable.
Posted : 21/07/2025 1:05 pm
tm
 tm
(@tm-2)
RE: Crash Detected
I just upgraded my mk4s to CORE one and this was the first problem after startup.  Changing the code to add M104 0 fixed it….but wth…
do I bother opening a ticket and hours of frustration ?
Posted : 14/08/2025 1:07 am
Page 2 / 2
