					                		CORE One SMD fuses - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/core-one-smd-fuses/</link>
                <lastBuildDate>Fri, 15 May 2026 08:16:09 +0000</lastBuildDate>
                        <title>RE: CORE One SMD fuses</title>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/core-one-smd-fuses/#post-754602</link>
                        <pubDate>Wed, 18 Jun 2025 15:50:53 +0000</pubDate>
                        <description><![CDATA[Thanks for the reply. I already knew all that from my research before coming here.The issue is several choices in different values, that I do not know, such as fast blow/slow blow..etc. Not ...]]></description>
                        <content:encoded><![CDATA[<p>Thanks for the reply. I already knew all that from my research before coming here.</p><p>The issue is several choices in different values, that I do not know, such as fast blow/slow blow..etc. Not sure if this is even the right type. it's from a post dealing with the XL's Modular Bed Board. Hence, having the specs clears this up!</p><p>h<a title="SMD fuse" href="https://www.littelfuse.com/assetdocs/littelfuse-fuse-154-series-data-sheet?assetguid=a8a8a462-7295-481b-a91b-d770dabf005b" target="_blank" rel="noopener">ttps://www.littelfuse.com/assetdocs/littelfuse-fuse-154-series-data-sheet?assetguid=a8a8a462-7295-481b-a91b-d770dabf005b</a></p><p> </p><p> </p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>J</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/core-one-smd-fuses/#post-754602</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/core-one-smd-fuses/#post-754600</link>
                        <pubDate>Wed, 18 Jun 2025 15:14:14 +0000</pubDate>
                        <description><![CDATA[I did not pay close attention when I assembled my Core One, and am away from the printer right now. Aren&#039;t those SMD fuses the self-resetting polymer type? I.e. if they trigger, you just swi...]]></description>
                        <content:encoded><![CDATA[<p>I did not pay close attention when I assembled my Core One, and am away from the printer right now. Aren't those SMD fuses the self-resetting polymer type? I.e. if they trigger, you just switch off the printer, let things cool down, and you can try again without having to replace the fuses?</p>
<p>Edit: Ah, no -- found a photo now. These are indeed conventional fuses which will "blow". But I would expect their electrical ratings to be the same as the automotive fuses which were used before. This assumes that the change was just for better manufacturability (fuse holders can be placed via the pick &amp; place machine) and no electrical changes were made.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/core-one-smd-fuses/#post-754600</guid>
                        <title>CORE One SMD fuses</title>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/core-one-smd-fuses/#post-754589</link>
                        <pubDate>Wed, 18 Jun 2025 13:50:47 +0000</pubDate>
                        <description><![CDATA[My xBuddy Board has the new style SMD fuses instead of the old school auto type. Does anybody know the specs and have a link with more info? I&#039;ve found similar types, just not sure of the ex...]]></description>
                        <content:encoded><![CDATA[<p>My xBuddy Board has the new style SMD fuses instead of the old school auto type. Does anybody know the specs and have a link with more info? I've found similar types, just not sure of the exact one needed. I know it's just a low amp fuse, but their are choices to be made and I'm not an EE (just a dumb redneck)</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/core-one-smd-fuses/#post-754589</guid>
