					                		Core One + Print Fails (Bed adhesion? Nozzle positioning?) - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/core-one-print-fails-bed-adhesion-nozzle-positioning/</link>
                <lastBuildDate>Tue, 09 Jun 2026 20:26:08 +0000</lastBuildDate>
                        <title>RE: Core One + Print Fails (Bed adhesion? Nozzle positioning?)</title>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/core-one-print-fails-bed-adhesion-nozzle-positioning/#post-788832</link>
                        <pubDate>Thu, 09 Apr 2026 19:58:54 +0000</pubDate>
                        <description><![CDATA[Posted by: @kvriend I&#039;m in touch with Prusa Support, unfortunately it takes quite a while to get a reaction. So far no luck. I am considering sending the printer back under warranty as it do...]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="610162" data-postid="788822" data-mention="kvriend"><div class="wpforo-post-quote-author"><strong> Posted by: @kvriend </strong></div><p>I'm in touch with Prusa Support, unfortunately it takes quite a while to get a reaction. So far no luck. I am considering sending the printer back under warranty as it doesn't function as intended.</p></blockquote><p>Can you run the manual belt calibration and check the belt tension? It could be they are too loose. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/core-one-print-fails-bed-adhesion-nozzle-positioning/#post-788832</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/core-one-print-fails-bed-adhesion-nozzle-positioning/#post-788822</link>
                        <pubDate>Thu, 09 Apr 2026 18:54:57 +0000</pubDate>
                        <description><![CDATA[I&#039;m in touch with Prusa Support, unfortunately it takes quite a while to get a reaction. So far no luck. I am considering sending the printer back under warranty as it doesn&#039;t function as in...]]></description>
                        <content:encoded><![CDATA[<p>I'm in touch with Prusa Support, unfortunately it takes quite a while to get a reaction. So far no luck. I am considering sending the printer back under warranty as it doesn't function as intended.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>KVriend</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/core-one-print-fails-bed-adhesion-nozzle-positioning/#post-788822</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/core-one-print-fails-bed-adhesion-nozzle-positioning/#post-787442</link>
                        <pubDate>Thu, 26 Mar 2026 13:32:23 +0000</pubDate>
                        <description><![CDATA[Closer up image. Same artefact is on the support, leading me to believe that that might cause it to break more easily causing the print to fail.
&nbsp;0492ee2c-img_0770.jpeg]]></description>
                        <content:encoded><![CDATA[<p>Closer up image. Same artefact is on the support, leading me to believe that that might cause it to break more easily causing the print to fail.</p>
<div id="wpfa-185509" class="wpforo-attached-file"><a class="wpforo-default-attachment" href="//storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/wpforo/default_attachments/1774531943-0492ee2c-img_0770.jpeg" target="_blank" title="0492ee2c-img_0770.jpeg"><i class="fas fa-paperclip"></i>&nbsp;0492ee2c-img_0770.jpeg</a></div>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/core-one-print-fails-bed-adhesion-nozzle-positioning/#post-787442</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/core-one-print-fails-bed-adhesion-nozzle-positioning/#post-787440</link>
                        <pubDate>Thu, 26 Mar 2026 13:30:55 +0000</pubDate>
                        <description><![CDATA[Thanks! The shroud seems (optically at least) fine and unharmed by the blob event. after printing something smaller without problems it seems I’m back again to square one when I tried someth...]]></description>
                        <content:encoded><![CDATA[<p>Thanks! The shroud seems (optically at least) fine and unharmed by the blob event.</p><p> </p><p>after printing something smaller without problems it seems I’m back again to square one when I tried something bigger. Could it be underextrusion? I’m considering either getting a new nozzle to try (and using them exclusively for one type of plastic only) or getting in touch with customer service, since I have to throw away so much wasted filament so often. That’s not normal right? <br />(Closer image in next reply, typing from my phone now so only one attachment per post allowed)</p>
<div id="wpfa-185508" class="wpforo-attached-file"><a class="wpforo-default-attachment" href="//storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/wpforo/default_attachments/1774531856-6e5a566b-img_0768.jpeg" target="_blank" title="6e5a566b-img_0768.jpeg"><i class="fas fa-paperclip"></i>&nbsp;6e5a566b-img_0768.jpeg</a></div>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/core-one-print-fails-bed-adhesion-nozzle-positioning/#post-787440</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/core-one-print-fails-bed-adhesion-nozzle-positioning/#post-787439</link>
                        <pubDate>Thu, 26 Mar 2026 13:07:20 +0000</pubDate>
                        <description><![CDATA[If you don&#039;t have the filament and nozzle to hand the part is available via the link at the top of this page.Cheerio,]]></description>
                        <content:encoded><![CDATA[<p>If you don't have the filament and nozzle to hand the part is available via the link at the top of this page.</p><p>Cheerio,</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Diem</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/core-one-print-fails-bed-adhesion-nozzle-positioning/#post-787439</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/core-one-print-fails-bed-adhesion-nozzle-positioning/#post-787333</link>
                        <pubDate>Wed, 25 Mar 2026 20:58:34 +0000</pubDate>
                        <description><![CDATA[I&#039;ll try PETG first before ordering PCCF (I suspect I need a hardened nozzle for that as well.). Thanks for the advice! Posted by: @diem According to:material: PCCFBut you would probably do ...]]></description>
                        <content:encoded><![CDATA[<p>I'll try PETG first before ordering PCCF (I suspect I need a hardened nozzle for that as well.). Thanks for the advice!</p><blockquote data-userid="50813" data-postid="787324" data-mention="diem"><div class="wpforo-post-quote-author"><strong> Posted by: @diem </strong></div><p>According to: https://www.printables.com/model/1167816-core-one-printable-parts/files</p><p>Recommended material: PCCF</p><p>But you would probably do better in two stages, one in PETG to get a slightly better air flow followed by the working copy in PCCF - and with that, print another for the spares box.</p><p>Cheerio,</p></blockquote><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/core-one-print-fails-bed-adhesion-nozzle-positioning/#post-787333</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/core-one-print-fails-bed-adhesion-nozzle-positioning/#post-787331</link>
                        <pubDate>Wed, 25 Mar 2026 20:57:40 +0000</pubDate>
                        <description><![CDATA[Posted by: @conrad-2 I can&#039;t tell exactly but it sounds like you aren&#039;t slicing the models yourself. IMO, slicing is printer-specific and I&#039;d never try to print anything, save for a premade ...]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="601564" data-postid="787326" data-mention="conrad-2"><div class="wpforo-post-quote-author"><strong> Posted by: @conrad-2 </strong></div><p>I can't tell exactly but it sounds like you aren't slicing the models yourself. IMO, slicing is printer-specific and I'd never try to print anything, save for a premade temperature tower, that I didn't slice myself. That way I know it's sliced for my nozzle, my filament and the speed and temperature I want. Print success should be near 100% for most things, though I admit to a lot of redesign before I'm happy with anything.</p></blockquote><p> </p><p>Hi! I usually  slice the models I print myself, sometimes I print via the Prusa app with easyprint, which has more limited slicing options afaik than the desktop application. Ideally the success rate is higher indeed. Hopefully I can get closer to 100%.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/core-one-print-fails-bed-adhesion-nozzle-positioning/#post-787331</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/core-one-print-fails-bed-adhesion-nozzle-positioning/#post-787326</link>
                        <pubDate>Wed, 25 Mar 2026 20:08:34 +0000</pubDate>
                        <description><![CDATA[I can&#039;t tell exactly but it sounds like you aren&#039;t slicing the models yourself. IMO, slicing is printer-specific and I&#039;d never try to print anything, save for a premade temperature tower, th...]]></description>
                        <content:encoded><![CDATA[<p>I can't tell exactly but it sounds like you aren't slicing the models yourself. IMO, slicing is printer-specific and I'd never try to print anything, save for a premade temperature tower, that I didn't slice myself. That way I know it's sliced for my nozzle, my filament and the speed and temperature I want. Print success should be near 100% for most things, though I admit to a lot of redesign before I'm happy with anything.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Conrad</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/core-one-print-fails-bed-adhesion-nozzle-positioning/#post-787326</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/core-one-print-fails-bed-adhesion-nozzle-positioning/#post-787324</link>
                        <pubDate>Wed, 25 Mar 2026 20:01:54 +0000</pubDate>
                        <description><![CDATA[According to:material: PCCFBut you would probably do better in two stages, one in PETG to get a slightly better air flow followed by the working copy in PCCF - and with that, print another f...]]></description>
                        <content:encoded><![CDATA[<p>According to: https://www.printables.com/model/1167816-core-one-printable-parts/files</p><p>Recommended material: PCCF</p><p>But you would probably do better in two stages, one in PETG to get a slightly better air flow followed by the working copy in PCCF - and with that, print another for the spares box.</p><p>Cheerio,</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/core-one-print-fails-bed-adhesion-nozzle-positioning/#post-787324</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/core-one-print-fails-bed-adhesion-nozzle-positioning/#post-787321</link>
                        <pubDate>Wed, 25 Mar 2026 19:46:58 +0000</pubDate>
                        <description><![CDATA[Posted by: @kvriend This was with the default 0.4mm nozzle. Not sure what you mean by &quot;separate from the heat break tube&quot;, it&#039;s one of those long nozzles with a copper bit attached. There ar...]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="610162" data-postid="787314" data-mention="kvriend"><div class="wpforo-post-quote-author"><strong> Posted by: @kvriend </strong></div><p>This was with the default 0.4mm nozzle. Not sure what you mean by "separate from the heat break tube", it's one of those long nozzles with a copper bit attached. </p></blockquote><p>There are 2 types of nozzles compatible with the Nextruder. There is the "standard" setup where the nozzle is attached to the heatbreak tube and the "V6" setup where the heatbreak tube and nozzle are separate. In the later case both screw into the heatblock. Care needs to be taken that the nozzle is tightened only when it is hot otherwise filament can leak out and create a "blob of doom." </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/core-one-print-fails-bed-adhesion-nozzle-positioning/#post-787321</guid>
