Core one PEI Sheet became bumpy after trying atemperature tower for ASA
Bambus
(@bambus)
So i wanted to do some filament calibration for some leftover stratasys ASA and when i remove the PEI plate, i noticed that the side of the sheet that was in contact with the heatbed became bumpy.
Both sides also got the bubbles.
Im not sure how visible the bumps in the image are
I used this upload for the tower (core one, standard nozzle, ASA): https://www.printables.com/model/39810-improved-all-in-one-temperature-and-bridging-tower/files
Anyway, is this expected to happen or did i do something wrong?
This topic was modified 2 months temu 2 times by Bambus
Opublikowany : 10/02/2026 11:12 am
jan.d.slay
(@jan-d-slay)
RE: Core one PEI Sheet became bumpy after trying atemperature tower for ASA
This is normal behavior for the adhesive film.
For ASA, I would recommend using a textured or satin printing plate.
Opublikowany : 10/02/2026 11:29 am
Bambus
(@bambus)
how much does it affect adhesion of prints with pla, petg or abs?
also is there any information on prusas website that i didnt see?
on their printplate maintenance site where they list what materials work with what printplates, it just said use gluesticka
Opublikowany : 10/02/2026 12:03 pm
Bambus
(@bambus)
i just checked https://help.prusa3d.com/article/smooth-steel-sheet_196550 and it says its "Main attributes Ideal for printing PLA, HIPS, ABS/ASA, composite materials (metal/wood)."
How is it ideal if it makes one side of the printplate unusable?
Opublikowany : 10/02/2026 12:31 pm
jan.d.slay
(@jan-d-slay)
A small counterexample:
Yesterday, I “destroyed” my PEI printing plate. My PETG print was so good in the first layer that the film detached from the carrier layer. Normally, I remove the printed part when it has cooled down a little. Unfortunately, in the case described, it was cold and I forgot to warm it up beforehand.
As I said, the bubbles are normal. They will disappear again over time.
A release agent to make it easier to remove the printed part is the best choice.
In my opinion.
Opublikowany : 10/02/2026 12:41 pm
Prusa says not to worry... Page 52 of the 3D Printing Handbook for the Core One, which describes the smooth PEI sheet:
If you notice small bubbles appearing beneath the PEI layer on the flexible print sheet, just flip it over and print on the other side. After a few days or weeks, the bubbles should disappear. The bubbles have no effect on the print quality
Edit: So the user needs a few more of these plates, unless two prints (on two sides) every "few days or weeks" are enough...
Opublikowany : 10/02/2026 1:17 pm
2 ludzie polubili
Bambus
(@bambus)
The bubbles are not the problem.
If you look at the image you can see that the side of the sheet that touched the heatbed got bumpy.
So i did not remove the print to harshly because the now bumpy side didnt touch the print at all.
The thing im asking is if the bumpiness (not the bubbles) are normal and if it will cause any problems with adhesion since the plat isnt as flat as it was
I am aware of the bubbles and ive seen and read about them.
Opublikowany : 11/02/2026 10:34 am
jan.d.slay
(@jan-d-slay)
No, my printing plate looks similar and I don't have any adhesion problems. I once read that if adhesion problems arise, you can also lightly roughen the film with wet sandpaper. I haven't done that yet because I'm worried that I won't be able to remove the printed object.
The adhered film offers good adhesion, no matter how uneven it is or how many bubbles there are.
That's also one reason why I only print PETG, ASA, and TPU on textured or satin-finished printing plates. The risk of destroying the film is too high when temperatures rise (ASA, PETG, etc.).
That's my opinion.
Opublikowany : 11/02/2026 10:51 am
Artur5
(@artur5)
If you print large parts in ASA, a smooth sheet has better adhesion than the satin/textured and that helps to prevent warping issues. The drawback is that you MUST use release agent/adhesive on the plate or you risk damaging the PEI surface.  It's also true, in my experience, that after printing a lot with filaments that need a high bed temperature (100C and above), the  PEI layer and/or the adhesive bonding it to the steel core may become bumpy or swollen. That depends on the quality of plate, of course. Prusas are more resilient, but I've had some Chinese smooth plates that became unusable aftter a few months because of this issue. Poking the surface of the swollen part with your finger you notice that it has turned soft and elastic. That's bad because the load cell that calibrates the Z offset is fooled by that and the first layer will be too squished.
Opublikowany : 11/02/2026 11:27 am
1 ludzie polubili
Posted by: @bambus
No, I can't see how the slight waves would cause adhesion issues. Their amplitude seems to be a fraction of the first-layer height. But they might be visible on glossy prints, which can be a nuisance for surfaces you want to look at.
Opublikowany : 11/02/2026 11:34 am
1 ludzie polubili
