Core One Nominal Chamber Temp
Chad
 Chad
(@chad)
I have a Core One and recently added an MMU3 to it. Before I added the MMU, I had set the min and max chamber temps to help prevent the fans from running too much. I found the overcooled the chamber causing bed adhesion and warping vs keeping the chamber a bit warmer. Especially with how the fans are placed.
The fan used to only kick on when I reached max chamber temp. Now I keep seeing the fans kick on and it's using that min temp as the "nominal" temp to control the chamber too. Basically it's now controlling the chamber temp to the min temp I set in the filament settings. I've tried searching for nominal temp in the gcode and slicer settings. I'm not sure if something changed in recent firmware or when I upgraded to the MMU3 it changed the logic.
I have 6.4.0+11974 currently installed
Posted : 24/01/2026 9:30 pm
