Core One crash/restart
Seite 4 / 14
John Doe
(@john-doe-25)
RE: Core One crash/restart
Fell for it again. Burning through ~1kg of ASA gave me 0 reboots, but doing 3 hours of PLA on structural profile I already got ~4 reboots, J guess it is PSU acting weird on low temps and it has to be replaced. (I got replacement, just didn't install it yet)
Posted by: @john-doe-25
Hi everyone, before the PSU came to me, I tightened all the cable ties in printer (learned that the connectors vibrating is a big nono and need to be arrested when researching building voron) and I also moved printer a bit to the left and started printing voron parts....
And magic happened! 25+ hours of various printing with no restarts.
Really hope it helps anyone.
Returning the printer anyway due to other hardware flaws with the machine that I paid 1000€ for.
Veröffentlicht : 30/05/2025 12:45 pm
darkmattermaker
(@darkmattermaker)
For what it's worth, I replaced my PSU and it did not change the behavior.
Veröffentlicht : 30/05/2025 3:04 pm
noumenonsense
(@noumenonsense)
Mitglied
Hello, I've been following this thread since I got my Core One. I have the same issue. Mine sounds most similar to darkmattermaker where it reboots primarily during long engagements of the x axis motor. If I let it sit there and reboot enough times, it will eventually throw a puppy error where it can't communicate with the xbuddy extension board.
I also have my printer hooked up to a UPS for troubleshooting - mine measures power draw. I didn't think it was PSU related because it's not rebooting when it draws the most power (when it's heating up the bed and element). I checked all of the cable connections I could get to easily and all of that seems to be fine.
After being able to trigger 2 reboots by simply touching the X axis motor while printing, I got to thinking that this may be a grounding issue. The chassis is powdercoated it looks like, and there are specific spots masked off to allow contact.
Using a multimeter, I looked for continuity between the X motor and the chassis ground. On my unit, there is no continuity measured from the bright screws at the top of the motor to the chassis on the X motor - but there is continuity from the same spot on the Y motor.
I hooked up a jumper between one of the X motor screws and the exposed chassis ground right below where the X motor is mounted on the left side of the unit. I have my left panel removed to make troubleshooting easier - this might not be as easy to do with the panel installed. I would include a picture, but the 'Add Media' button in the editor does not appear to do anything.
I've been checking on it regularly and I don't believe the printer has rebooted since I did this yesterday morning. My theory is that a static charge is building up in the X axis motor chassis due to the belt motion, and because it isn't grounded, eventually discharges somewhere that triggers the power panic. This is my first 3D printer, so maybe this doesn't make sense, but either way it seems to have helped. The issue has been intermittent and seems to be project-dependent, so I'm hesitant to say it's fixed for certain. I'm in the middle of a long print, but there are other projects I can print when I'm done that would more reliably trigger a reboot.
I am curious whether anyone else with a multimeter can confirm whether their working or non-working Core One has continuity between the X motor top screws and chassis ground.
Andrew
Veröffentlicht : 02/06/2025 3:03 pm
6 weiteren Personen gefällt das
darkmattermaker
(@darkmattermaker)
Posted by: @noumenonsense
Andrew
I checked mine with a multimeter. I do not get continuity between the bright screws on the top of either motor and the chassis ground. Shouldn't the green wire in the motor cable provide ground? Forgive me, I'm not an electronics engineer so I'm not super familiar with this sort of thing.
Veröffentlicht : 03/06/2025 1:07 am
(@juergen-4)
@noumenonsense, that's a promising idea and observation! On my Core One, both motors are grounded to the chassis. But that must just be luck, not by design -- looking at the build instructions, and if I recall correctly from my own build, none of the areas where the mountings screw heads meet the frame has been masked off before powder coating.
For what it's worth, I have not experienced any random crashes on this printer. But take that with a grain of salt: While I have done a couple of large prints, these did not involve long, straight, fast motor runs. So I might just not have gotten into the "danger zone"...
@darkmattermaker -- the four motor cables only connect to the internal motor windings, two windings with two connections each. These windings are isolated from the body of the motor (and the shaft with the pulley). Hence, if the belt movement would cause some buildup of static electricity, that could only be discharged via a separate ground connection to the motor body -- or via a spark discharge through the powder coating, which might derail the microcontroller or the "power panic" logic.
Veröffentlicht : 03/06/2025 6:57 am
(@juergen-4)
Duplicate post   edited
Veröffentlicht : 03/06/2025 6:58 am
(@juergen-4)
Veröffentlicht : 03/06/2025 6:59 am
(@juergen-4)
Veröffentlicht : 03/06/2025 7:02 am
(@juergen-4)
Sorry about the quadrupled post. The server had stopped responding just when I clicked "Submit", so I clicked another time after 15 seconds or so. Not sure where the third and fourth post come from? I have asked the moderators to clean up.
Hi Jurgen,
By the time I saw this post and the report asking for deletion of the duplicates , other people had posted below you,
and from memory, If I try to delete a mid thread post, the ones below it also get deleted..
I didn't want to spoil the flow of the thread
Veröffentlicht : 03/06/2025 10:14 am
Sarah
(@sarah-4)
This is a good theory. I'm wondering if mine sitting on carpet played any role too regarding static buildup. I had it on the floor for a few weeks until I could get a table sturdy enough for it as I was afraid it would tip the dresser I initially put it on. I'll have to try one of the offending prints with those movements (in my case it was organizer baskets) again and see how it does. The partial nozzle clogs seem to correlate with it in my case too from what I can tell.
Andrew
Veröffentlicht : 03/06/2025 12:01 pm
mkohv
(@mkohv)
Mitglied
I had similar problem for two weeks. Tried all the things mentioned in the earlier replays - did not help. Small prints, like calicat were ok but larger ones got so many restarts that quality dropped beyound acceptable even if the printer continued printing. But now I have two good quality 15 hour prints at my desk together with some smaller ones. Not a single failure anymore. I just replaced the official, fancy metal USB stick with my old one - that was it.
Veröffentlicht : 03/06/2025 8:37 pm
Raaz
 Raaz
(@raaz-2)
Just to add to this: I had a few USB stick related errors too. Just to be extra safe, I've bought the SanDisk MobileMate (really small microSD reader) and a SanDisk Max Endurance microSD card. I'm using two of these in my dashcam for a few years now and didn't have a single error.
Not the cheapest storage solution for the Core One, but also not really expensive and definitely worth it for me to be as safe as possible.
I just wish for a black edition of these SD cards... Maybe I'll paint it..
Veröffentlicht : 04/06/2025 1:55 am
Mostafa Fawaz
(@mostafa-fawaz)
Mitglied
I have the same problem. Printer dies and restarts on diagonal movements. Prusa support is clueless. Printer is basically bricked now.
Veröffentlicht : 04/06/2025 4:05 am
JFrosty
(@jfrosty)
I just replaced the USB and I'm printing a file that has consistently restarted 20-30 mins into the print. It's currently at 1 hour and 24 mins. So it looks like after all this troubleshooting and replacing parts, it might be as basic as a USB issue. 🤣
I'll keep you guys updated, it's a 7 hour 41 mins print. Hopefully I can get back to printing as I have a fairly big backlog due to the printer downtime. 🤣
Veröffentlicht : 04/06/2025 9:18 am
JFrosty
(@jfrosty)
False alarm. 3 hours 30 mins in it restarted. I thought it might be too good/easy to be true. Back to square one. Sigh.
Veröffentlicht : 04/06/2025 11:27 am
darkmattermaker
(@darkmattermaker)
Posted by: @frosty-2
Bummer! I tried swapping the USB stick early on, I didn't have any luck either.
Has anyone heard back from support with potential causes or solutions?
Veröffentlicht : 04/06/2025 8:56 pm
darkmattermaker
(@darkmattermaker)
Andrew
So, this idea has been stuck in my mind since reading your post. Neither my X- nor Y-axis stepper housings were connected to the chassis ground. So, because my Core One is a MK4S conversion I took the old MK4S heatbed power cables and used them to connect the steppers to ground. On the X-axis side I connected it to one of the key-slot screws holding the xBuddy box to the rear panel. On the right hand side I did the same thing using the key-slot screws holding the power supply. Chassis ground continuity is now registering on all four stepper motor mounting screws, for both steppers.
Since then I've run multiple tests of the problematic file and it's passed every time. Five times in a row so far. It's never done that with this file. The best I've managed to get is one time through and a failure on the 2nd try. I'll be convinced if I can make it to 10 tests without an issue. So far it looks very promising.
One could probably achieve the same results by simply sanding off the powder coating on the underside of the gantry where the stepper motor mounting screws are. One screw per stepper would probably be all that's needed. Remove the screw, sand off the powder coat, reinstall the screw. In theory anyway.
Veröffentlicht : 04/06/2025 10:51 pm
5 weiteren Personen gefällt das
noumenonsense
(@noumenonsense)
Mitglied
Posted by: @darkmattermaker
Andrew
Glad this seems to be helping. On my end, I believe I was able to finish the long print (4 days) I was working on without the printer rebooting once I grounded the motor. I also restarted the original project I encountered the problem on - that one would almost always reboot on the first layer, and it's been printing for hours now without an issue. I'm not watching it 24 hours a day, but it used to reboot so frequently that I'd see it if I just stood there long enough. Usually a reboot is obvious because some filament will ooze out of the nozzle when it's restarting, and that will get stuck to the print when it resumes. Other times it will simply ruin the print, or throw the puppy error, etc.
I do have a case open with Prusa support, but they are operating under the assumption that either a faulty component or the user's environment is to blame. I think this is a pretty reasonable mindset for tech support, but if I'm right, this is a design/QC issue. My printer was preassembled, but it sounds like grounding the motor housing to the chassis was not ensured in the design based on what others are saying in this thread.
I wanted to wait until I had a pretty strong case before presenting this theory to Prusa support, but if it helped darkmattermaker too, and Jürgen's working printer has both motors grounded, I think I'll email them back and let them know what I found. I tried a lot of other troubleshooting steps before this, including using a different flash drive, new nozzles, etc. Obviously there are probably many reasons one of these could reboot, but so far grounding the X motor has been the only thing that's helped me to the point where I feel optimistic.
Thanks all for checking this.
Veröffentlicht : 05/06/2025 12:37 am
darkmattermaker
(@darkmattermaker)
So, it just finished 10 tests of the print I was having trouble with. They all worked. That has never happened. Best I could get before was 1 success followed by a failure. Even that was rare, it was almost always a failure on layer 3. Thanks for posting your idea, I don't think I would have figured this out without it. I would have been spending weeks swapping parts in and out and never finding the actual cause.
Seriously though, great work! This will hopefully help a lot of people, and hopefully we can convince Prusa they've got an issue that needs to be addressed. I too have a case open with support and I will check in with them tomorrow and let them know how things have been going.
Veröffentlicht : 05/06/2025 1:30 am
N8&Joey
(@n8joey)
Andrew
This sounds promising!!
For those of us who are a bit less electrically/technically savvy in experience, would you be willing to share photos of your recommendations? I want to try this approach, but also don’t want to create a bigger problem with my machine.
Appreciate any and all help you can share!
Veröffentlicht : 05/06/2025 1:40 pm
Seite 4 / 14
