Core One crash/restart
Página 12 / 17
Bob Hayes
(@bob-hayes)
Miembro
RE: Core One crash/restart
On two occasions my Core One has restarted when I am reinstalling the print sheet.  Is this happening to others and does anyone have a solution.
Respondido : 04/11/2025 7:34 pm
Posted by: @bob-hayes
Try turning off the door sensor in the firmware under: Settings -> Hardware -> Door Sensor
Respondido : 04/11/2025 9:43 pm
GreenPea
(@greenpea)
Some people mention static discharge, could this be your case?
Loving the learning curve!
Respondido : 04/11/2025 10:10 pm
David H. Brown
(@david-h-brown)
That's a new one to me, but it sounds like you also might be generating some static electricity that would be better off elsewhere. Try grounding yourself while holding the build plate before you touch it to the print bed.
To find a convenient ground in the CORE One itself, use your multimeter to look for continuity between any of the 8 socket head cap screws around the Z axis rods at the front bottom. If you measure continuity (< a couple ohms) between any two of them, those two are very likely electrically connected to the sheet metal frame which should be fairly well grounded (assuming correct assembly). I found 3 with continuity in my kit-built unit and could presumably ground myself by touching them... if I could remember which ones they were 🙂 . The techniques described in this thread for grounding the X/Y motor screws (scratching off the powder coat, star washers) should work down there, too, to get more or more convenient screws grounded.
There's also an accessible ground point on the LCD board accessible if you tilt the control panel forward. With the printer switched off of course, I was able to take about an 9"/200mm length of 30AWG (0.05mm2) hookup wire, strip off 6"/150mm from one end and wrap that tightly around the crimped part of the connector. (Easier if you temporarily pull off that grounding connector, but don't lose it in the base!) Then I removed  about 1"/25mm of insulation from the other end and routed the wire up behind the magnetically attached front piece so you can easily touch it at the bottom of the enclosure to ground yourself and hopefully remove excess static from the flex plate you're holding.
This picture should give you an idea of what I did...
A thin blue wire connected to an existing spade connector
...but I haven't had the problem you describe, so YMMV.
It would presumably be bad for the electronics if little bits of stray wire came loose around the display LCD electronics, so if you think this might help you, you might add a bit of electrical tape or even heat-shrink tubing around that added connection.
Esta publicación ha sido modificada el hace 4 months por David H. Brown
https://www.printables.com/@DavidHBrown_24313https://www.thingiverse.com/davidhbrown/designs
Respondido : 04/11/2025 10:29 pm
1 les gusta
There are at least two causes of crashes. The first is static building up on the x-motor belt which discharges through the door sensor switch. Grounding the two motor casings will fix this. The other (which I never experienced) was some people experienced crashes opening the door. This was mitigated through turning off the door sensor.
Respondido : 04/11/2025 10:38 pm
1 les gusta
chmax
(@chmax)
Let me add a possible 3rd one: if the OP was walking on a surface that loaded him with static and he touched the printer when installing the plate... zzap! Same effect as the motor one build with the charge coming in from outside. I managed to do this once on my mk4s ... after that, especially on dry winter days, touching some grounded object before the printer became routine...
Respondido : 04/11/2025 10:49 pm
1 les gusta
Matt Meola
(@matt-meola)
Miembro
I bought some star washers off amazon and they worked perfectly.  I didn't even scratch off any coating by hand.  Just added a washer to 1 screw on the x and y motor.  I didn't even have to take off any panels.  Easy peezy.  No issues since and I've done a handful more prints including ones that previously crashed.
Here are the exact lock washers I bought:
METALLIXITY Internal Tooth Washers (M3x6mm) 100Pcs, 304 Stainless Steel Internal Serrated Lock Washer
https://www.amazon.com/dp/B0BRK69HTP
Respondido : 04/11/2025 11:14 pm
1 les gusta
Gigarez
(@gigarez)
Miembro
My core one started to crash and restart repeatedly every couple of minutes at 60% of a big print that takes almost all the X-axis. Found this thread and first I tried with alligator clips to ground just the X and Y motors. Continued the print and it didn't crash anymore after 30 min but unfortunately the print has lifted from the bed.
I used a multimeter to check for ground on the motors. X and Y motors are not grounded because the mounting screw doesn't make any contact with bare metal on the gantry. The three Z motors are sitting on an adapter piece between so grounding the mounting screws on top side doesn't work.
I have now proceeded to open up the panels and added toothed washers after sanding away some of the coating right at the motor screws. X and Y-axis should be now grounded.
The Z-axis 3 motors was a bit trickier to ground since they have an adapter in between. I had to do it on the bottom side of the printer and tried to "snap" a terminal connector between the motor screw and underside of the bottom plate. The other end of the cable just screwed with a toothed washer into one of the unused holes on one of the bottom brackets.
I will do another 10h big print which was crashing consistently. Hopefully this grounding was the problem.
Respondido : 21/11/2025 6:00 pm
nforester
(@nforester)
Miembro
I've had same issues with crashing/restarts lately. It could crash 5-8 times during 1 hour print. Now performing first print after ground repair. What I did: took out one bolt that was holding X axis motor, grinded off powder coating with dremel and assembled back together. Checked that it has continious signal from x (and y) axis motors housing to ground pin in power outlet.
Will reply in few days how did it went.
If this text is getting smaller, it means your monitor is being carried away!
Respondido : 22/11/2025 8:30 pm
1 les gusta
nforester
(@nforester)
Miembro
It looks like it helped. Already 5+ hours printing without any errors.
Thanks to prusa community👍
Respondido : 23/11/2025 10:16 am
2 les gusta
Posted by: @gigarez
It is probably not necessary to ground the Z motors. They do not drive a belt (which is probably a key ingredient in the triboelectric charge buildup), and they move by much smaller distances.
Also, the Z motors are insulated in all off-the-shelf Core Ones and kits because, as you say, they are mounted on those plastic flex elements. Nevertheless, users have consistently reported that the crashes disappeared for them after merely ensuring that the X and Y motors are grounded.
Respondido : 24/11/2025 1:24 pm
Gigarez
(@gigarez)
Miembro
Yeah, I figured it wouldn't do much grounding the Z-axes but hey, while I was at it already then might as well do them, too. It makes me feel better knowing they're now also grounded. 🙂
Respondido : 24/11/2025 2:05 pm
Gigarez
(@gigarez)
Miembro
My big print went smoothly without any crashes. I think grounding was the problem.
Prusa should address this issue. Maybe add a few toothed washers and an extra instruction step while installing the motors.
Respondido : 24/11/2025 10:33 pm
1 les gusta
Bonnifur
(@bonnifur)
Miembro
You wouldn't be able to snap a picture quick by chance? I started having this issue and want to make sure I am looking at the right place. I also just upgraded to 6.4.0 firmware after I noticed the issue so maybe the firmware could possibly fix it, however after reading through 12 pages I doubt a firmware update will fix it.
Posted by: @nforester
Respondido : 26/11/2025 11:34 pm
Posted by: @bonnifur
On the previous page in this thread, this post has good pictures which show where and how to remove the paint to ground the motor chassis. Certainly worth doing! There is no way a firmware change can fix this, since the underlying static discharge is a "proper" hardware issue.
Respondido : 27/11/2025 9:05 am
1 les gusta
nforester
(@nforester)
Miembro
Sure.
I have used this screw , it goes up all the way to motor (marked with yellow).  Removed a bit of powder coating under screwhead. If you have a multimeter then I would check Y axis also.
Respondido : 27/11/2025 4:20 pm
Bonnifur
(@bonnifur)
Miembro
Thank you!
Posted by: @jurgen-7
Respondido : 27/11/2025 7:34 pm
Tim
 Tim
(@tim-21)
Miembro
The fix is installing inside star washers on two screws, one on each motor. All that grounding the earlier post talks about is not needed. The Extruder carraige is already properly grounded. So all that needs to be done is to ensure the X and Y motor cases and connected to that frame.  The issue is the powder coat paint is thick, and it's common for it to insulate the motors. Arcs happen, and the printer resets.
This is my left motor. I did the same to the easiest to access screw on the right motor.
Respondido : 29/11/2025 6:20 am
3 les gusta
HarryH
(@harryh)
Miembro
I can confirm that the crashes on my printer were resolved when I added star washers to the X & Y motor. Been printing this way for several weeks now with no issue.
Respondido : 01/12/2025 10:56 pm
1 les gusta
Inbox
(@inbox)
This is an interesting thread and whoever identified the fix needs a shout out of recognition, it was good work.
Having looked at what is going on, the fix works because it is stopping charge build up in the stepper motor, rubber belts are well known for charging materials up through the triboelectric effect and is serious risk in bulk material handling. In the Core One I believe the ungrounded stepper is creating a capacitor between the body and the mounting chassis with the plastic spacer acting as a dielectric. The fix basically shorts out the capacitor preventing it holding charge.
For me, powder coat, paint, etc over mounting holes isn't surprising, it just isn't on the radar of the mechanical engineers as masking off these areas just costs money and adds complexity so the stepper motor grounding is just pot luck, it may happen it may not.
The link between long x-y transitions and the reboot issue but not happening with short transitions is because the longer transitions are able to generate more charge, I think the coupling path for this is down through the stepper motor into the driver. The motor rotor and chassis are one electrical part, this gets charged and basically sparks over to the board inside the motor and down the cabling into the controller causing the reboot. I can imagine if Prusa haven't already fixed this, the Core One L will suffer this problem but on a bigger scale.
Respondido : 05/12/2025 11:52 am
Página 12 / 17
