Constantly recalibrating
Pagina 4 / 5
Chris Ewing
(@chris-ewing)
Utenti
RE: Constantly recalibrating
I don't know if this is related or not, but I have a pre-assembled Core One.  I was having the constant recalibration issue.  5 days ago I noticed it having issues leveling the print bed and noticed a clacking sound when the print head moved quickly.  I watched it closely and noticed play in the print head.  I stopped the print and jiggled the print head and found it was loose!  The four screws shown here were almost falling out.  I re-tightened them (with some loctite for insurance) and re-assembled everything and found my bed leveling issues solved and haven't had the constant recalibration issue since.  That last part may be a coincidence, but you may want to wiggle your nextruder and see if it's loose.
Postato : 13/05/2025 7:52 pm
1 persone hanno apprezzato
darkmattermaker
(@darkmattermaker)
It's likely that it's not the belt tension that's the problem. It's the gantry not being square. Squaring the gantry is more important the tightening the belts. See this article here:
https://help.prusa3d.com/article/adjusting-belt-tension-core-one_845048
See steps 1 through 5. There needs to be ZERO play between the gantry and the front stops. Loosen the belts until you get there. Then, tighten them back up slowly, alternating sides, until you reach as close to 85hz on each belt WHILE keeping the gantry aligned. This requires frequent checks while adjusting the tension back up.
Postato : 13/05/2025 11:37 pm
SimplyTheDude
(@simplythedude)
I re-adusted my belts using this guide. There was play in the gantry before, but not after adjusting. But it didn't help. What I found has helped was the bed being close to the top, but that can't be adjusted after powering it off, since the zero is wrong.
Posted by: @darkmattermaker
Postato : 14/05/2025 10:11 am
George
(@george-4)
I noticed that if i leave the head at its parked position in the corner, it has a higher chance to just keep on banging trying to find its limits. If however i first move it away from where it checks, the next time it needs to calibrate it just bangs the side for a lot less. Its as if that travel distance sort of pretensions the belt?
Dunno. just something i noticed.
Postato : 15/05/2025 8:31 am
kjgouldstone
(@kjgouldstone)
already done this a couple of times, makes no difference, squaring the gantry
Postato : 15/05/2025 8:40 am
iftibashir
(@iftibashir)
Also have the same issue - spends ages hitting the extruder on the corner back and forth.
Today I got sick of the noise and reset the printer - after which it went straight through!
Surely this can't be 'normal' behaviour??
Postato : 18/05/2025 12:02 pm
2 persone hanno apprezzato
George
(@george-4)
Yeah, i started doing it as well. When i see it starts banging more than normal i just hit reset.
Posted by: @iftibashir
Postato : 18/05/2025 12:31 pm
_bmt
 _bmt
(@_bmt)
Check here: https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/z-axis-trouble-but-only-when-printing/
I noticed mine was getting stuck in a loop during the homing and leveling checks. After adding gcode to pause heating before those steps, it passes a lot faster. That was on Sunday and I haven't had a chance to print anything else since then, but I'm optimistic this workaround fixed at least some of my issues.
Postato : 21/05/2025 12:10 am
psychlore
(@psychlore)
Add me to this list, as well.
Just upgraded my MK4S to a Core One over the weekend, and it does this stupid banging loop from time to time. Why does it do it some times, but not others?
Postato : 03/06/2025 10:03 pm
Prusa still seems to think that this is not a hardware flaw or firmware bug, but that fixing it would constitute an "enhancement". 🤪
https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/4582
Postato : 03/06/2025 10:09 pm
Christoffer Ramqvist
(@christoffer-ramqvist)
Utenti
I've also had this issue since I built my Core One kit a month ago, the banging can go on for several minutes, sometimes it works right away. The gantry is perfectly squared, and belts are tightened exactly right. Hoping this will be solved in a later firware update!
Postato : 11/06/2025 1:23 pm
Dedalo
(@dedalo-2)
Posted by: @valkyrie3dp-2
My core one recalibrates home before every single print for almost 5 minutes. Is anyone else having this issue?
Postato : 11/06/2025 11:48 pm
Dedalo
(@dedalo-2)
My friend if yours is only doing that, let me tell you that you are lucky, mine is making me crazy, for some one that just came from the i3 mk3 after 4 years and is still running like a champ, this is so annoying, the printer is always trying to overwrite prusa slicer values, if I want to change the filament I have to do it twice if I'm going to change the material because i cant find a way to tell the printer that is going to be another, it just remember the last one you loaded, and then starts to hit the corner like crazy, now they add a cleaning nozzle nonsense that honestly I don't know what they where thinking, the idle temperature is another one, there is another temperature the printer goes before actually reaching the temp you need,I tried to change that one and does not allow me to edit the PETG material, very disappointing for a 1500 dollars 3d printer, don't get me wrong,I am a prusa guy, but honestly this is so frustrating, if there is any one that have a link or something explaining and fixing these things, pleaseeee help me out here
Postato : 11/06/2025 11:56 pm
psychlore
(@psychlore)
Update on mine. Read the instructions that were given to another forum member, about using one of the 10mm+ wrenches to force alignment via bending the brackets.. and after spending over an hour getting it into shape.. tuning and retuning the belts..
Mine now does the following:
2 taps on the y.. 2 taps on the x... 4 bangs corner to corner.. 4 bangs corner to corner... and prints. Consistently, that's the pattern it does.
So, while not entirely gone, it's at least no longer maddening with the constant banging over and over...
... now if I could just figure out what on earth is causing the annoying vibrations at the bottom of the enclosure, when the Z axis is moving up and down. (Pressing on the bottom of the enclosure, from underneath, makes the sound go away, entirely... have re-tightened everything, and everything prints perfectly.. so starting to care less and less about the acoustic annoyance)
Posted by: @psychlore
Postato : 15/06/2025 9:07 pm
psychlore
(@psychlore)
... spoke too soon, apparently.
Some prints.. woosh.. works fine.
Other prints, it'll sit there and re calibrate.. incessantly....
REALLY beginning to hate the inconsistency of it.
Postato : 26/06/2025 1:27 am
Iak_madrac
(@iak_madrac)
Utenti
RISPONDI: Constantly recalibrating
“I found a solution that worked on my Core One. I completely loosened the front belt tensioners, then disassembled the Nextruder down to the plate where the belts start and end. I made sure there was the same number of teeth on both sides. I reassembled the plate, reassembled the Nextruder, and re-tensioned everything. After doing this, the XY axis doesn’t give me any issues anymore.”
Postato : 01/07/2025 4:37 pm
luc.e
(@luc-e)
Having the same issue. When I put the printer on a solid base I had less banging going on.
Postato : 12/09/2025 12:13 pm
Print_Fandango
(@print_fandango-2)
Utenti
the latest ALPHA firmware has issues with homing I think... I recalibrated mine, did belts, etc... now it does twice as much banging at the beginning that it did with the last FW or is this another issue.
I think I am near the end of my PRUSA adventure, I just bought an H2D and I just send prints to the thing and no issues. If PRUSA does not figure how to make the core one worth the $1100 USD dollars, I think I am very close to done.
Postato : 15/09/2025 11:22 pm
Ckobar
(@ckobar)
Hmm with the old fw I had the typical 8 bangs. The new fw does it much better.
A strobe app for your handy is a super solution if the Prusa strobe is not working well for you.
Postato : 16/09/2025 7:14 pm
Print_Fandango
(@print_fandango-2)
Utenti
I upgraded the FW and started messing with the belts and homing became 12 bangs.
I dont understand the instructions and nobody is willing to explain properly here nor provide a video, so until better instructions are provided I will just stick with the previous Fw.
Postato : 16/09/2025 8:09 pm
Pagina 4 / 5
