Can't exit Change Filament Screen when MMU3 Active
ChuckT
(@chuckt)
Membre
Recently my MMU3 on my CoreOne stopped working correctly.  First it would not completely unload the filament from the PTFE tube from the Nextruder back to the MMU3.  The MMU3 would then get stuck and not move.  Then it would break the filament and then try to load the new filament.  Further, when I tried to print a part, the filament would load then print for 20 seconds and then unload the filament and run into the problem stated above.  After clearing the system, it would repeat the process again.  Now I have only the two screens that show up when I start the machine as attachments.
I checked all sensors and cleaned both the MMU3 sensor, removed all extraneous filament pieces and dust.  Now all I get is the two screens upon start up and the CoreOne is locked.
I have now returned the CoreOne to a none MMU3 setup (single filament) and the CoreOne printer works as it should.  Apparently the problem lies with the GCODE that the MMU3 system that is trying be cleared.  If there is anything else I can try it would be appreciated.
The system is running current software configuration for the CoreONE and I have flashed the MMU3 system several times with the correct version of the software.
Screen displayed after system start up. Display screen after Change Filament
Publié : 23/09/2025 4:43 pm
