Can I adjust the Z Steps on my CoreOne?
I went to print something that was about 200mm x 30mm x 100mm. The X & Y were spot on, but when I measured the Z, it was 101mm instead of 100mm. Is there any way to adjust the Z steps on the printer? With my Ender 3 S1 Pros, this was very simple to do:
- Bring the nozzle to the bed
- Move it up 100mm
- Measure how much it actually moved up
- Do some math
- Input the new value in the printer's settings section
I wasn't able to find anything like this with the Prusa. Or am I just missing it? I understand it can be compensated for in the gcode, but if I purchased more printers and the Z isn't calibrated the same on all of them, then the gcode solution falls apart.
Posted : 05/03/2025 3:57 pm
