Buddy camera antenna
Laura F Farrell
(@laura-f-farrell)
While trying to assemble I managed to rip the tiny PCB antenna off the Buddy camera. I dissambbled it and see that it's just a ufl attached antenna that might be easy to replace. Does anybody know what spec the PCB antenna is so I can find a likely compatible one?
Respondido : 30/08/2025 8:30 pm
RE: Buddy camera antenna
Something like this should work: Flexible PCB (FPC) Antenna
"Some filaments feel the rain, others just get wet"
- Bob Marley
Respondido : 30/08/2025 8:33 pm
Laura F Farrell
(@laura-f-farrell)
Interestingly, it still works even with the pcb bit ripped off, so it seems to be functional (even if the wifi signal is weak). But ordered a couple of similar ones designed for ble and wifi anyway.
Respondido : 01/09/2025 6:52 pm
k1mu
 k1mu
(@k1mu)
It's just a single wire - I soldered mine back on.
Respondido : 03/09/2025 4:19 pm
k1mu
 k1mu
(@k1mu)
Laura F Farrell
(@laura-f-farrell)
I replaced it with a very similar one from Pimoroni (it seems to be just a standard uFL wifi antenna) and the signal on my wifi router has changed from weak to strong.
Respondido : 04/09/2025 3:27 pm
crackers28
(@crackers28)
Miembro
Hi there,
My Core One buddy just fell apart. Would you happen to have a model number for the ufl antenna you fitted at all? Or any other details of it?
Thank you.
Regards,
Dave
Respondido : 10/10/2025 6:46 pm
k1mu
 k1mu
(@k1mu)
I'm using one of these: https://www.amazon.com/dp/B077SVP7PN
Quite a bit larger, which may help if your wifi is marginal near your printer.
(Full disclosure: I work for Amazon.)
Respondido : 12/10/2025 4:43 pm
