					                		Brittle filament broke in filament tube, how do I remove tube? - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/brittle-filament-broke-in-filament-tube-how-do-i-remove-tube/</link>
                <lastBuildDate>Sat, 06 Jun 2026 02:08:57 +0000</lastBuildDate>
                        <title>RE: Brittle filament broke in filament tube, how do I remove tube?</title>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/brittle-filament-broke-in-filament-tube-how-do-i-remove-tube/#post-787824</link>
                        <pubDate>Tue, 31 Mar 2026 05:44:01 +0000</pubDate>
                        <description><![CDATA[what it says on the tin. I loaded cheap, brittle filament that broke in the tube when i tried to unload it. how do I remove it?(prusa one+)That happened to me too. Unfortunately, I caused th...]]></description>
                        <content:encoded><![CDATA[<blockquote data-userid="0" data-postid="787701" data-mention=""><p>what it says on the tin. I loaded cheap, brittle filament that broke in the tube when i tried to unload it. how do I remove it?</p><p>(prusa one+)</p></blockquote><p>That happened to me too. Unfortunately, I caused the problem myself. I usually always use PTFE tubing with a 3mm inner diameter. But when I replaced the tubing, I ended up with one that was 2mm.The filament got so tangled and jammed up that I had to throw out the entire PTFE tubing along with the filament :-DSo: Please also check if you have a PTFE tube with a larger inner diameter. Just my opinion.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>jan.d.slay</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/brittle-filament-broke-in-filament-tube-how-do-i-remove-tube/#post-787824</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/brittle-filament-broke-in-filament-tube-how-do-i-remove-tube/#post-787801</link>
                        <pubDate>Mon, 30 Mar 2026 21:20:58 +0000</pubDate>
                        <description><![CDATA[Remove the Bowden tube from the top of the Nextruder push some filament through on the right side, push out the broken pieces.]]></description>
                        <content:encoded><![CDATA[<p>Remove the Bowden tube from the top of the Nextruder push some filament through on the right side, push out the broken pieces. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/brittle-filament-broke-in-filament-tube-how-do-i-remove-tube/#post-787801</guid>
                        <title>Brittle filament broke in filament tube, how do I remove tube?</title>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/brittle-filament-broke-in-filament-tube-how-do-i-remove-tube/#post-787701</link>
                        <pubDate>Sun, 29 Mar 2026 23:25:50 +0000</pubDate>
                        <description><![CDATA[what it says on the tin. I loaded cheap, brittle filament that broke in the tube when i tried to unload it. how do I remove it?(prusa one+)]]></description>
                        <content:encoded><![CDATA[<p>what it says on the tin. I loaded cheap, brittle filament that broke in the tube when i tried to unload it. how do I remove it?</p><p>(prusa one+)</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>5UNM0TH</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/brittle-filament-broke-in-filament-tube-how-do-i-remove-tube/#post-787701</guid>
