Pagina 2 / 2
Precedente
RE: Belt Tension Issues on New Core One – Layer Shifting & Unreliable Tuner App
That's not entirely right. It may level the bed at the top when using the correction dust cobers (or ither means to change z calibration stops) but then be misaligned at the bottom.
The problem is the z screws arent exactly the same pitch. The printer seems to adjust for this, at least some. I need 1.5mm trying to force it with the dust covers, but using no corrections I only see .5mm deviation on 200mm tubes, one printed at each z-screw. I havent tried a .5mm correction to see if I can get that to zero yet. But I think the printer firmware has compensation built in.
Postato : 29/09/2025 6:56 pm
Pagina 2 / 2
Precedente
